Stereo & Electronics - Anyone mount amps behind rear seat back?
nightmarechevy
07-18-2009, 01:53 PM
Tried a search but didn't come up with anything. Has anyone mounted an aftermarket amp behind their rear seat? I bought the car with the amps mounted in the rear seat location a few years back and am going to throw a rear seat back in it. I was thinking about moving them but would like to keep them where they are for a stealth install. I am thinking about cutting a notch out of the seat back but wasn't sure how comfortable the seats would be with half of the foam cut out. I would keep the seat back down most of the time so airflow wouldn't be a problem. Here are a few pics of the car as it sits right now.
http://i15.photobucket.com/albums/a372/nightmarechevy/camaro/a.jpg
http://i15.photobucket.com/albums/a372/nightmarechevy/camaro/100_0929.jpg
cbailey
07-18-2009, 04:35 PM
Im pretty sure with that setup you have there, if you were to put seats over it, it would definitely overheat fast. If you want comfort get some memory foam. That stuff in thinner qualities is still more comfortable that thicker stock seat foam.
pheer
07-18-2009, 05:45 PM
yeh, if you puts seats directly on those, the exhaust fans won't have anywhere to push air to....
who needs passengers...
nightmarechevy
07-18-2009, 06:21 PM
I would have the seat back folded down most of the time anyway. I only drive the car a few miles every few months if I'm lucky and it is usually just me in the car. I would like to take my wife and son for a short cruise every now and then.
dragonrage
07-19-2009, 12:03 PM
You can do this.
-Use efficient amps, like Class D - yes, full range class D amps exist, usually ICEpower, and also some Tripath ("Class T"). Eclipse, Alpine, Pioneer and others have them.
-Get amps with no fans
-Cut the carpet and thermally couple the amps straight to the car sheet metal. You will need a relatively flat mounting surface, and I'd consider using thermal interface material from a company like Bergquist. (You could use thermal grease like you use for computer processors, but it's messy)
-Don't puncture the gas tank if you use screws. I don't know how much clearance there is, but on the top of the rear deck, clearance is low.
-Don't use ridiculously overpowered subwoofer amps
You won't need the seat to be down at all.
xephona
07-19-2009, 11:10 PM
There was one guy who posted pictures, no idea where they are though.. I will hunt more later. But what he did was mounted the amp and subs back there, and built a box that resembled the seat back, and put the seat fabric right over it without the foam. Looked like they were real seats, and shouldn't cause too much heat since the fabric is breathable.
dragonrage
07-20-2009, 11:14 AM
I still can't understand how you guys think it's acceptable to just delete the rear seat. You don't need to do this.
xephona
07-20-2009, 05:12 PM
It is acceptable because no one sits there... EVER. People do NOT fit back there. Especially if you add a roll cage.
nightmarechevy
07-20-2009, 09:41 PM
Did some thinking and measuring on the amps and decided I would have to take out way to much foam to be remotely comfortable. I pulled the amps and mounted the seats up and decided to throw the amps on the back deck. Now I just need to get some time to hook the amps back up.
dragonrage
07-21-2009, 04:17 PM
Lots of people did when I had my Camaro, and still do with my sister and her T/A.
pentavolvo
07-21-2009, 04:22 PM
once u add a cage the rear seat is useless
KEE AUDIO
07-21-2009, 07:23 PM
Another thing to consider for people who have not purchased amps yet is that most newer models have a MUCH smaller foot print then older models like the ones pictured. One of the new Infinity 5-channel amps I currently have is only 14" x 7" x 1 3/4". For a 5-channel that is pretty small. There 800watt monoblock is the same size as well. Alot of the other audio companies have also been doing this making hiding amps alot easier while still maintaining good power levels.
nightmarechevy
07-21-2009, 11:38 PM
Have the back seats in and the amps halfway mounted up and wired. Here are a few mock up and teaser pics. Still need to finish hooking up one amp and put the panels back together.
http://i15.photobucket.com/albums/a372/nightmarechevy/camaro/100_0046.jpg
http://i15.photobucket.com/albums/a372/nightmarechevy/camaro/100_0048.jpg
http://i15.photobucket.com/albums/a372/nightmarechevy/camaro/100_0049.jpg
http://i15.photobucket.com/albums/a372/nightmarechevy/camaro/100_0050.jpg
http://i15.photobucket.com/albums/a372/nightmarechevy/camaro/100_0052.jpg
pentavolvo
07-22-2009, 12:20 AM
me personally i would ditch the cap or atleast hide it and hide the distro also
Engine_HP
07-22-2009, 12:58 AM
^^^ hide them in the spare tyre space, thats what i did :D
nightmarechevy
07-22-2009, 08:10 AM
I have a sub box with a 12 there so no go. Also I don't think the cap looks bad, it has a blue voltage readout so I like to be able to glance at it and see the voltage (even though it isn't totally accurate).
dragonrage
07-22-2009, 09:14 AM
I would sooner dump the Audiobahn crap.
nightmarechevy
07-22-2009, 06:03 PM
I have had no problems at all with any of my Audiobahn components and they are paid for so they will be staying until I have problems.
VeitSSki8701
07-24-2009, 01:17 AM
look at my cardomain page, copy the address from my siggy and there is a page dedicated to my sound system set up. you can get some ideas if you'd like. I made a custom box for the back deck and it looks super nice.
cbailey
07-24-2009, 03:23 AM
Holy shit thats alota wires!! Gonna need darker tint...if you want to keep what you have.
nightmarechevy
07-25-2009, 12:50 PM
Haven't had time to post them lately but here are a few finished pics.
http://i15.photobucket.com/albums/a372/nightmarechevy/camaro/100_0053.jpg
http://i15.photobucket.com/albums/a372/nightmarechevy/camaro/100_0055.jpg
http://i15.photobucket.com/albums/a372/nightmarechevy/camaro/100_0057.jpg
http://i15.photobucket.com/albums/a372/nightmarechevy/camaro/100_0062.jpg
http://i15.photobucket.com/albums/a372/nightmarechevy/camaro/100_0060.jpg
shoemike
07-26-2009, 01:22 PM
:thumb:
thecobrahunter
07-26-2009, 02:20 PM
Here's mine:
http://carphotos.cardomain.com/ride_images/1/1571/4521/3927260202_large.jpg
http://carphotos.cardomain.com/ride_images/1/1571/4521/3927260201_large.jpg
nightmarechevy
07-26-2009, 02:37 PM
Looks good cobrahunter.
