Tools & Fabrication - PR lenth-checker tool question
View Full Version : PR lenth-checker tool question
monster81
07-23-2009, 07:55 AM
How accurate is this PR length-checker tool in the pic is compared to the adjustable PR ?
ghettocruiser
07-23-2009, 01:28 PM
I dont see how that thing lets you figure out PR length at all. Maybe on an adjustable valvetrain set up. Im assuming that bolts in place of the rocker? Maybe Im not seeing how it works.
I just used the adjustable PR. Super easy, and it works. Got it from summit. Comp cams makes it. Took about a day to get.
J.
Bad Blue WS6
07-23-2009, 02:35 PM
yeah, the ones ive see always look like a pushrod. ive never seen one like that b4.:emb:
budhayes3
07-28-2009, 02:11 PM
That appears to be a pr length checker for a sbc...
monster81
07-28-2009, 03:13 PM
thats right, its a SBC PR length checker,,,i never used such a tool,according to the instructions both ends of the PR and the valve tip should contact this tool at the same time while valves closed.if PR touches first then i shoud replace with a shorter PR...sounds pretty easy :/ guess ill stick to the adjustable PR length checker
M93Z
07-28-2009, 06:59 PM
In my experience they're not very accurate, on an LT1 that tool showed my pushrod as being the correct length, however when I checked the same valve with an adjustable pushrod the correct length was actually .050 shorter.
