Convertible Vehicles - Installing Rear LCA's
View Full Version : Installing Rear LCA's
BigT2002
07-28-2009, 04:43 PM
Anyone have experience with them on the car?? Any different from the T-Top install guides I've seen?? Never done it before and I have a feeling I'll be doing it myself
cablebandit
07-28-2009, 05:44 PM
they are the same...easy. make sure to tighten the bolts TIGHT and ONLY tighten them with the rear end loaded like on ramps or something...not with the rear hanging. Bolts to at least 100ft/lbs
BigT2002
08-02-2009, 06:37 PM
thanks man. pretty painless and probably one of the best mods I've ever done! My rear end feels like a brandnew car with them
BMR Sales
08-06-2009, 10:33 AM
Hello, like the other poster had stated change the arms with the suspension loaded but only do one side at a time. We recommend torque the bolts to 80ft lbs. If you have any questions please give me a call.
FireHawkMike
08-10-2009, 01:00 PM
I put the BMR lca's on myvert along with the panhard bar. very easy, and got rid of my squeaks and rattles from worn factory bushings.
99'CajunFirehawk157
08-10-2009, 01:04 PM
I assume by this you mean only take off & replace one side at a time so nothing shifts?
To the OP yeah pretty easy job...
BMR Sales
08-12-2009, 09:01 AM
Yes thats exactly what i meant. You have alot less problems doing it that way. :thumb:
xny1989
08-12-2009, 10:35 AM
the only thing I'd add is to make sure you put grease on the bushings before installing. It's a tight fit and the grease will help get them in and line up the bolt holes.
