Pontiac G8 2008-2009 - boosting the g8
View Full Version : boosting the g8
parish8
08-03-2009, 11:30 PM
a pair of precision 6062's :D goal for now is to get it done before drag week, turn it up to the limit of the stock fuck system. then later work on the fuel system and turn it up a little more. the intercooler is done, charge pipe to the engine is done. turbos are mounted where i want them under the car. now i just have to tie it all together.
http://neufamily.org/images/g8gallery/images/g8%20025.jpg
http://neufamily.org/images/g8gallery/images/g8%20037.jpg
http://neufamily.org/images/g8gallery/images/g8%20043.jpg
http://neufamily.org/images/g8gallery/images/g8%20044.jpg
http://neufamily.org/images/g8gallery/images/g8%20051.jpg
http://neufamily.org/images/g8gallery/images/g8%20053.jpg
Eric Bazan
08-04-2009, 12:43 AM
Dude, youre a BMF'r! Ha ha!!! Lovin' it!!!
SSGoat
08-04-2009, 01:26 AM
sweet jesus thats fuken badass, how much did that run ya?? what supporting mods do u have or are needed for the g8 to be tt'd?
'02 WS6
08-04-2009, 01:28 AM
Are you running a BAP on your current fuel system? There are people now that are running less power than what you're going to be at and already having some starvation issues.
parish8
08-04-2009, 07:31 AM
right now just hp tuners and an lc1. mt dr's are next.
the g8 is stout, engine, tranny and rear will hold a lot of power.
parish8
08-04-2009, 07:32 AM
no bap. since everything else is stock and i will be running low boost i think i will be ok for now. i do have a bap laying here i could hook up but dont the injectors run out at the same time as the fuel pump?
GRRRR8
08-04-2009, 03:23 PM
Very nice! Love those Nova wagons.
G8GT721
08-04-2009, 04:12 PM
sweet!
SigmaX6
08-04-2009, 07:26 PM
*tosses warrenty out the window* we don't need that :)
04BlackGmc
08-04-2009, 08:07 PM
should be sweet!
best color
parish8
08-04-2009, 09:29 PM
http://neufamily.org/images/g8gallery/images/g8%20067.jpg
Eric Bazan
08-05-2009, 08:33 AM
More pics please :)
norm8332
08-05-2009, 09:19 AM
The injectors run out before the fuel pump. At least for me on my setup they did.
Stampede4ever
08-05-2009, 12:16 PM
Can you post pics of the turbos mounted?
Thanks.
LsxCody
08-05-2009, 01:18 PM
Looking good man. I was kinda hoping you would build another turbo truck lol. But still looks great
Bad Habit Bird
08-05-2009, 02:55 PM
I'm looking forward to your results!
I could be wrong but from what I have seen the stock injectors are good for about 420-440rwhp in a boosted application, the stock pump is good to 550 or so to the wheels.
parish8
08-05-2009, 04:01 PM
550 on the stock pump? that would be great.
parish8
08-05-2009, 04:03 PM
Thanks.
all the pics i have are here >> http://neufamily.org/images/g8gallery/index.htm
http://neufamily.org/images/g8gallery/images/g8%20057.jpg
Stampede4ever
08-05-2009, 07:44 PM
Do you have to use an oil return pump?
Thanks.
parish8
08-05-2009, 07:51 PM
Thanks.
no. i still need to figure that out.
rocket5979
08-05-2009, 09:20 PM
I would suggest that you do run a return scavenger pump with as low as those turbos are mounted. The oil would literally have to drain uphill to even go back into the pan itself. That doesn't make for good drainage out of the CHRA.
G8GT721
08-05-2009, 09:26 PM
where are you taking your oil supply from? oil Sender?
parish8
08-05-2009, 09:28 PM
yes, that is the plan
parish8
08-05-2009, 09:29 PM
whatever that fitting is near the oil filter. it was made for this type of thing.
G8GT721
08-05-2009, 09:34 PM
yea i may eventually move mine to that location, the APS kit takes the oil from the factory sender location, and then uses the scavenge pump to dump it in the oil fill spot. My oil pressure drops to 18-20 at idle when the car is warmed up and I only see about 40 at start up & wot.
parish8
08-05-2009, 10:08 PM
did you have any problems with the pasenger side air filter pipe fitting. the instructions show it running in the same spot as the drivers side. right between the motor mount and oil pan. it wont fit there due to the tranny lines.
i think i can get it to run up behind the motor mount but was curious what you did on your car.
frcefed98
08-05-2009, 10:22 PM
Custom tranny lines, route em how you need em and be done with it.
parish8
08-05-2009, 10:43 PM
yeah, i will do that if i have to. i think there is room without having to move them.
G8GT721
08-06-2009, 04:14 PM
sorry i cant remember but i know everything is very tight, heres a picture i doubt it will help but here it is
http://i323.photobucket.com/albums/nn453/kroche721/APS%20TT/P1000403.jpg
LsxCody
08-08-2009, 12:04 AM
What are you're goals for the car
parish8
08-08-2009, 01:52 AM
i want it to keep it as nice to drive as i can. maybe someday get into the 10's.
for now mid 12's or faster with no other mods than bolting the turbos on and tuning it, maybe some tires on the stock wheels.
LsxCody
08-10-2009, 03:23 PM
I think it should be faster than just a 12 second car. Any updates
LsxCody
08-10-2009, 03:53 PM
G8GT721
08-10-2009, 04:29 PM
i also have a TT G8, im at 7psi, and the restof my mods are in my sig. Here are my times from when i went to NED friday night for the street night, on my 18" all season.
fyi-this was my first time at the track, so you should have no problem being mid to low 12's
12.687 @ 118.3 first run ever
12.270 @ 118.3
12.503 @ 112.3
16.342 @ 87.8 last run with lots of wheel hop so i let off and i still almost beat a mustang lol
http://i323.photobucket.com/albums/nn453/kroche721/scan0001.jpg
parish8
08-10-2009, 06:17 PM
i am not getting this done quick enough. drag week will be here in no time.
all i got done since last week are the "down pipes". then i started looking at tieing in the wg's and they look real tight. if i could put them in backwards it would be easy on both sides but to put them int he right direction is tight.
car will be running stock 2.25" exhaust, stock cam, stock injectors and low boost. it should be quite a big quicker than mid 12's once i work thru some of that stuff. i figure injectors and cam should allow me to turn it up over 500rwhp but that is not going to happen right away.
parish8
08-10-2009, 06:19 PM
12.270 @ 118.3
12.503 @ 112.3
nice numbers. i will be down a little from you on hp but better tires so yeah, mid to low 12's should be easy.
LsxCody
08-10-2009, 11:12 PM
I thought it would be quicker than that. Good luck with it. All you're projects turn out great anyway
parish8
08-12-2009, 08:43 PM
now this is a high performance converter swap. :D i need to hurry the hell up, drag week is coming up fast.
http://neufamily.org/images/g8gallery/images/g8%20072.jpg
http://neufamily.org/images/g8gallery/images/g8%20075.jpg
http://neufamily.org/images/g8gallery/images/g8%20078.jpg
G8GT721
08-12-2009, 08:47 PM
new high flow cats, i have those too! :thumb:
Stampede4ever
08-13-2009, 09:49 AM
The build looks great. I have a few questions, where did get the flange to bolt up to the stock exhaust, and have you decided on what oil return pump you will use?
Stampede.
parish8
08-13-2009, 05:58 PM
got the flanges here. i wish they were a little thicker >> http://www.verociousmotorsports.com/Shop-by-Category/2-and-3-Bolt-Exhaust-Flanges-and-Gaskets_2/304L-Stainless-Steel-Laser-Cut-2-Bolt-Flange
yes i did order a pump. i went all out and got the expensive exa pump. http://www.turbowerx.com/Scavenge_Pumps/Exa-Pump/Exa-Pump.html?gclid=CJvs57LQoZwCFRBM5QodsiR7fQ
Stampede4ever
08-14-2009, 12:15 PM
Thank you for your input. Where did you get the ball and socket flange? Also when you have the cold side done can or will you post pics?
Stampede.
parish8
08-14-2009, 05:18 PM
i will keep taking pics.
i got the ball off of an old set of cats. not sure where to buy new ones. the ball is only 2.25" so it will be a place to upgrade along with the entire exhaust system someday.
SLPGTP
08-15-2009, 01:42 AM
Parish you are my hero. lol This is awesome. I can't wait to see what this thing can do. When is the dyno day?
Stampede4ever
08-18-2009, 04:10 PM
Anyup dates?
Thanks.
parish8
08-18-2009, 05:09 PM
Anyup dates?
Thanks.
i got the other turbo/wg set up done and bolted on. both turbos are permanently installed on the car. i had to clock them a little and clock one of the wg's. i fired it up for a sec to check for exhaust leaks and found none.
thats it:(. not enough time in the day. i should have 100% of what i need to finish it once i have time.
SLPGTP
08-18-2009, 05:29 PM
:drool:
parish8
08-18-2009, 10:59 PM
finally an easy project. did one of the charge pipes and it only took an hour or two :mrgreen: one more charge pipe, 2 air intake pipes and then oil stuff. wont be too long now.
http://neufamily.org/images/g8gallery/images/g8%20086.jpg
http://neufamily.org/images/g8gallery/images/g8%20087.jpg
http://neufamily.org/images/g8gallery/images/g8%20089.jpg
http://neufamily.org/images/g8gallery/images/g8%20085.jpg
98Camarod
08-19-2009, 01:24 AM
bad ass for sure. You are going to have to have a pump to get the oil to the pan. the wife wants to trade her car in, I think I have her hooked on the g8 gt, i'm just not looking for the up in the payment :cry:
parish8
08-19-2009, 07:14 AM
yep, going to have to use a pump.
Stampede4ever
08-19-2009, 11:54 AM
What size is your charge pipes?
Thanks.
parish8
08-19-2009, 05:04 PM
Thanks.
2" for the 2 charge pipes. 3" up.
allbaugh_04
08-20-2009, 08:51 PM
You were talking about a converter parish? What size and what tires you going to use, what day you racing?
Stampede4ever
08-21-2009, 03:02 PM
parish8: Where are getting your tubing from, and what is the price roughly?
Thanks.
parish8
08-21-2009, 05:11 PM
they have the nicest bends i have seen. some bends loose their shape when you cut them but not theirs. you can cut and clock a bend and it is perfectly round mid bend.
expensive. a 3" is $25
i wont be geting a converter anytime soon but when i do it will probably be a Circle D. i like the one in our wagon. if i am ready i might be going to mam next friday.
SLPGTP
08-22-2009, 07:20 AM
Let me know!!! I heard you were out with the Nova last night.
parish8
08-22-2009, 09:20 AM
wagon has some issues but it is getting faster. ran 6.40 last night and i am sure it has another .2 in the 60'
JCurtin
08-22-2009, 06:26 PM
this parish guy is slow....
parish8
08-22-2009, 06:31 PM
the g8 MIGHT run today:D
dyno tom told me when we get it runing call him up and we will get it on the dyno. "i dont care if it is 2am sunday night":D
JCurtin
08-22-2009, 06:39 PM
Sweeeeeeet. I still cant believe how fast you put that damn thing together. Shall we have some fun one night later this week? The g8 might want a rematch.
I'm flying back monday and installing the new trans and restalled converter(3800) tuesday. I have to run around monday and find a shop to swap the bellhousing and then its ready to go.
JCurtin
08-22-2009, 06:48 PM
How much are you thinking its going to do? What are they capped out at fuel wise? I need to get my broke ass back on the dyno, doubt it happens before we leave.
parish8
08-22-2009, 07:46 PM
car should be ready to make some runs next weekend. i need to get some tires on it.
on a dynojet the car is around 300rwhp stock. from what i understand i will be around 400-425rwhp(dynojet). not a giant gain.
then add injectors and a little more boost. then add a cam, then fuel pump. then upgrade my 2.25" exhaust.... should be 600rwhp before long.
allbaugh_04
08-22-2009, 11:03 PM
Damn, idk if i'll be able to come watch, unless you do it Friday night...
JCurtin
08-23-2009, 02:46 PM
Imagine that, same parts I need minus the exhaust lol
parish8
08-23-2009, 04:39 PM
http://neufamily.org/images/g8filespics/g8burnout.wmv
we had a little fun today. my hp tuners box took a crap so no tuning but we did make a couple of runs on the dyno just to see if it was safe to beat on the car.
stock should be in the 270-280rwhp range on a mustang dyno.
with a peek of 5psi it got 347hp/375tq
bumped it to 7psi and got to 375hp/400tq
both of those numbers were with very low timing. anywhere from 8deg down to 2deg so there should be a lot more power properly tuned. also the a/f ratio was low 11's and even into the high 10's so more power there too.
after we saw that it wasn't likely to blow up we went out on the street and ran it thru the gears. it seemed to like normal drive the best but was still shifting too high. power is falling off pretty hard up top. a combo of dropping boost up top and maybe the tiny exhaust? we were only at the 347hp setting when we went out for a spin.
seems like 400+rwhp should be easy with 7psi and tuning. i hope to get some mt's on there and get it tuned before next friday and then hit up the 1/8th.
car is VERY quiet. dyno tom said it was the quietest 375hp he has every heard :lol:
98Camarod
08-23-2009, 06:53 PM
Lets get some finished install pictures, damn :jest:
parish8
08-23-2009, 07:00 PM
we were in a mad dash to get it running so we could go for a spin. that and i have no lift so taking pics under the car always look like shit. cant get a good angle.
i have to get the car back up in the air to address some clearance issues. i will get some more pics then. pics of the scavenge pump. stuff like that. we put that right in the front wheel well. there is a pretty large empty spot near the drivers feet.
G8GT721
08-23-2009, 07:43 PM
we have a pretty good sleeper, nobody expects a white sedan to beat there ass
parish8
08-24-2009, 10:21 PM
went out for a gtech run. stock showed 13.49. at the 5psi/347hp setting i now see 12.80.
thats a decent start. now add a proper tune, boost and tires.
i have to say it feels slow as fuck. needs at least another 200hp. with the tune and 7psi it should be over 400rwhp(mustang). maybe that will start feeling quick.
i am communicating with hp tuners to find out what is up with my box. they do respond pretty quick but i wish they had a phone number and live tech help. i might end up paying for another slot on someone elses cable just so i can get tuning on it. 2-8deg of timing has to be killing me.
parish8
08-28-2009, 12:24 AM
woohoo. car is running strong. it actually puts you back in the seat now. front end comes up a shit ton and i am still at 5psi on the street.
after about 15 runs at c&s dynoshop tom got it dialed in pretty good. the thing seems to hate timing at peek tq. tom thinks it could be my restrictive exhaust or tiny cam. timing ended up around 11deg at peek tq and 15deg at the top. anymore and it would show knock. car was tuned with hptuners and a lc1.
5psi was 375rwhp.
7.2psi was 419rwhp :shock:
mustang dyno, 3rd gear pulls(forgot 4th gives better numbers on these 6speed autos), no lock up.
on that 7.2psi run the injectors were maxed and the a/f ratio was headed up. this was in an 80deg shop. no way i car run that boost level on the street without larger injectors. maybe 6psi but only if i am watching the scan tool and it isn't too cool out.
i think the ~7psi will be fine with some injectors.... damn, more money i might have to spend before drag week :bandhead: :lol: . those numbers seem decent to me considering stock cam and stock 2.25" exhaust with 5 mufflers.
i have some dyno video but dont plan on messing with it till after we go to the track tomorrow.
SLPGTP
08-28-2009, 12:37 AM
I wanna see a 12.0 or better. :) I will settle for nothing less! We need more video!
parish8
08-28-2009, 07:22 AM
i could see lower 12's but 400hp isn't all that much in a 4000lb car. might need another mod or two before it gets into the 11's.
SLPGTP
08-28-2009, 07:48 AM
Yeah I figured. But I've seen some people's mod lists and they are running 12.5's. Shouldn't be much more than 400hp cuz they are uncammed. I'm hoping the car surprises you the first time out. Get a cam in that thing and you should be putting down some serious power. I've seen cars with cam, header, and a tune run around 420hp. You should come out to KRP Saturday. I'd love to see that thing.
Stampede4ever
08-28-2009, 11:50 AM
Can you post some more pics of the finished project?
Thanks.
parish8
08-28-2009, 05:01 PM
Thanks.
i need to get it on a lift so i can get some pics. i tried taking pics with the car on stands and they dont show much.
G8GT721
08-28-2009, 05:22 PM
good luck at the track, i think mid to low 12's
parish8
08-29-2009, 03:08 AM
car didn't run so well tonight. best run was 8.26 at 87 with a 2.03 60' (12.8's?)
5psi, 91octane fuel from bp, 11.5deg of timing at peek tq, 15deg at 6000rpm. a/f ratio in the mid to lower 11's.
no matter what we tried we still got knock retard. ran the fuel from high 10's up to low 12's. definately got more knock retard while in the low 12's. thought it might be heat soak from sitting in the staging lanes so we let it cool off a little and that didn't help.
last thing we did was put the timing to a flat 10deg up top and make a run. no knock. at least we are learning something. it appears to be real knock that the sensors are seeing.
question is... should we be able to run 5psi with 11.5-15deg of timing on 91 octane?
thinking a meth kit should be next, then a converter.
TheFallen
08-29-2009, 04:40 AM
car didn't run so well tonight. best run was 8.26 at 107 with a 2.03 60' (12.8's?)
107 in the 1/8? is moving pretty well
parish8
08-29-2009, 09:51 AM
woops. not sure where i got that from. 87mph
parish8
08-29-2009, 05:55 PM
got some dyno video nothing crazy(yet) >> http://neufamily.org/images/g8filespics/g8dyno.wmv
04BlackGmc
08-29-2009, 06:21 PM
sounds like it needs some small things to get it going to where it should..
u are at a 12.8 now now im sure i did 8.4 last time out in the 1/8..
mine would get knocke around peak tq until i did the 160* and made it 12.5 AFr...
Eric Bazan
08-29-2009, 09:15 PM
Do you think the knock might be from the DOD lifters?
parish8
08-29-2009, 09:30 PM
like i said above when we pulled timing back to 10deg and all knock retard went away it makes me think the knock is real.
not really sure about anything and am open to ideas.
i am 99% sure the car is going to get a meth injection set up. should help with lots of things. i didn't want to spend any more money right now but as it sits it just isn't quick enough.
parish8
09-06-2009, 05:37 PM
got some newer pics up. http://neufamily.org/images/g8gallery/
also a new dyno numbers and track times after the AIS meth kit.
http://neufamily.org/images/g8filespics/477hp779et.wmv << thats a big file. for those of you that would rather read about the results i will type them up.
best numbers before the meth were 419rwhp/411tq on a mustang dyno. we were fighting knock. injectors were 100% a/f ratio was climbing fast. a safer 5psi gave us 375rwhp but even with it tuned with plenty of fuel and low timing we were still fighting knock at the track.
after the meth we got it turned up to almost 10psi, 16deg of timing, no knock at all, a/f ratio in the lower 11's, injectors at 80%. the meth kit was an AIS system with the trunk mounted tank and progressive controler. 2 14gph nozzles and pump running full blast by 8psi.
new numbers... 477rwhp/504rwtq. this is on a mustang dyno.
at the track i had to work the shift points a ton. shifting at 5600, any sooner and it falls off hard. i suspect valve springs. 1-2 shift is now commander at 5100 to get it to shift at 5600.
best et was 7.79@95 with a lowly 1.99 60'. running at 9psi. there is more in it as it sits.
these numbers are with the stock 5 muffler exhaust, stock dod cam, stock converter, stock injectors.
complete list of mods are. hp tuners with 2 bar os, lc1, twin 60mm turbos, 265/40/18 dr's on stock rims, AIS meth kit.
04BlackGmc
09-06-2009, 09:23 PM
nice improvment
98Camarod
09-06-2009, 09:56 PM
Get some good springs and cam in there and you will be flying.
Are those recent snow pics?
parish8
09-06-2009, 10:54 PM
nope, thats back when i got the car.
G8GT721
09-07-2009, 09:54 PM
Parish, it looks like the nozzles are located directly across from eachother on the nipple? (90 & 270 degrees) Is it ideal to have them like that and not seperated from eachother?
http://i323.photobucket.com/albums/nn453/kroche721/nozzle.jpg
Trav4011
09-08-2009, 04:38 AM
Parish.. Are those the new Billet Precison units? If so, you aren't anywhere near the peak efficiency range for those things. It needs more boost! ;)
Travis
parish8
09-08-2009, 06:11 PM
hell if i know. seems to be working well.:burn:
parish8
09-08-2009, 06:13 PM
Travis
yes they are. it has a little room to grow;)
parish8
09-17-2009, 08:37 PM
we are on drag week with the 67 wagon we built and the g8. g8 is doing well.
11.95@122 on sunday 9psi
11.90@122 on monday 9psi
11.87@122 on tuesday 10psi
11.44@124.5 on wedsday 10.5psi
11.87@122 on thursday 9psi
wedsday was at summit track. that place kicks ass. it was also perfect weather and i did the syty shuffle to help with the 60'. still only a 1.92 on that day so there is another easy .2 right there.
still stock cam, converter, 5 muffler exhaust. thinking exhaust, valve springs, a 3rd meth nozzle and then a little more boost will be the next mods.
G8GT721
09-17-2009, 09:40 PM
nice!, do you have a link to the meth kit you used?
parish8
09-17-2009, 10:55 PM
AIS trunk mounted progressive kit with 2 14gph nozzles running full blast.
Stampede4ever
09-21-2009, 11:53 AM
What is the SYTY Shuffle?
Thanks.
parish8
09-21-2009, 05:22 PM
Thanks.
pull up to the line and stage(both lights). put it in neutral. push the brakes hard. give the engine a good rev. brake pedal will sink farthur and you end up with more brake force than normal.
put it back in gear, then floor it while holding the brakes, wait till there is some boost and then let it go.
