Advanced Engineering Tech - Intake Manifold for Centri blower?
T/A KID
08-07-2009, 07:24 PM
The plenum of the stock LT1/LT4 intakes measures right at 2.88 liters which equates to 175ci (50% of a 350ci motor) For measurement sake 1liter=61ci. My intake measures 6.45liters=393ci. The rule of thumb in building intake manifolds is start at 50-75% of the motors cubic inch and you can go up to 120-130% of the CI, going more than that makes lagged throttle response and can slow the car at the track. Using this information this intake would be 112% on a 350ci, 1.03% on a 383 and 99% on a 396, which is prefect within those requirements. From the information above we can also derive that the stock intake barley has enough plenum for a Stock 350ci motor right at 50%, on a 383 that number lowers to a 34% and a 396 is 27%. Something I picked up from Joe Overton (fastest N/A LT1) is that rpm isn’t the issue with an LT1 intake it’s the plenum volume and the turbulence it creates. It becomes turbulent b/c of the small plenum; it starves the cylinders for airflow in the upper rpm levels which indirectly effects the performance of the small 3inch runners. This intake IMO would be a great candidate for a N/A application.
The runners have had a lot of attention since I felt that they where one of the biggest problems with the factory intake (well again that’s all relevant to how much rpm you plan to run as well, but the plenum is still an issue). The stocker measured right at 3inches in length which between the lengths of the intake runner of the head+intake that runs off the 5th harmonic wave. I decided against modifing the length in a physical sense, but I received some very good info from Larry Meaux (who is on this site every now and again) , he said, “The sharp knife-edged Runner entries are effectively "lengthening" the runners by causing a sharper harder hit on runner wave tuning. If the runner is a little too short for RPM range, a sharper divider can act like its slightly longer returning a more powerful wave at Intake Valve closing point. Knife-edge is used sometimes to effectively fool the manifold runner length into thinking it’s longer, and too much radius effectively fools the runner into thinking its shorter than it measures.” So by making the knife-edge entry I am tricking the runners into thinking there longer making more average TQ and HP.
Taper is often used on intakes to increase the FPS of airflow, but adding taper into a manifold’s runner actually shortens the runner. Since the runners on the LT1 intakes are so small in length it is best IMO to keep any taper out of the intake, and this will make the runner think its longer as well.
These actions may possible throw this intake in with the 4th harmonic wave, which would be nice for some more power gain.
The roof on the stock intake and the entry into the runners seem to be a big problem. On the stock intake the roof of the runner was lowered around .250 to get the injectors to fit into the rails. Over the years I have seen people raise the roofs .100-.125 without welding and around .200 with welding. I have raised the roof to around .350-.400. Again this goes back to working the runners for greater volume and I have a bell mouth "style" entry into the runners.
I worked the runners for greater volume, but I did not touch the gasket area. When installing the intake I plan on removing the top to see how well the ports line up. Air should not know when the intake/head starts or ends, should be one continuous runner.
The intake weighs right at 13lbs, on the same scale the intake before modding (stock form) weighed 19.2lbs. Many people convert Holley steathrams over for LT1/4's and they have to be around 35lbs. For comparison sake LSX style plastic manifolds (LS1, L76, LS2, LS7 etc weigh in the 10-12lb range)
Here are a few pics of the intake (A little old, but you guys will get the idea, looks better now, just no updated pics).
Before welding up the top of the intake I worked the on the inside of the intake, notice the entry bell entry near the top of the runner (the intake is actually smoother now as opposed to the pic) and notice the knife edged runner entry.
http://i69.photobucket.com/albums/i77/TAKID/DSC01054.jpg
http://i69.photobucket.com/albums/i77/TAKID/DSC01062.jpg
http://i69.photobucket.com/albums/i77/TAKID/DSC01161.jpg
Just for comparison sake here is a pic of my factoy LT4 intake worked over by a very reputable porter in the LTx community. Notice how only the TB opening has been worked over and the runners have been worked. The only way to work over the inside of the factory intake is to cut the top off. Other things I don't like the is the protrusions from the fuel rail crossover and fittings. Also the number 8 is right against the wall, that must be hurting flow into that cylinder. For that matter air likes radiused entries so air feeding from the top of the plenum would not flow as efficient as air from a bellmouth style entry.
http://i69.photobucket.com/albums/i77/TAKID/383Build5a1.jpg
The car has a D1SC at the moment (1400cfm) and in the near future I plan to uprade to a F1A Procharger (1650cfm). So I have a few questions regarding on what I could do to enhance the performance of the intake.
One of my main concerns is what about CSA are at the entry of the runner, since the car is boosted could I get away with a larger CSA as opposed to a N/A combo?
Does runner length matter on a blower application, I would think the intake harmonics would not matter since the intake manifold would be pressurized?
Would Taper, play a role in? IMO it would not since the airspeed is already probably twice as fast since the car has a blower. And again, if runner length is actually important on a build like this one, I can use all the runner length I can.
Plenum volume IMO is about perfect for a any N/A LT1 application (350-396 ci motors), but for a boosted application could a larger plenum be beneficial?
T/A KID
08-09-2009, 02:00 PM
Anyone have an opinion?
Speed Density
08-09-2009, 07:18 PM
Awesome craftsmanship, curious to see how it works out.
T/A KID
08-09-2009, 07:31 PM
Thanks, first intake I have ever done. I plan on ordering some Devcon or Splash zone Epoxy in the next few days to really clean up the exterior of the intake and to make some areas on the inside smoother as well (mainly right behind the TB area).
I have done a enormous amount of research on intake design and I have talked to several people in the LTX community that have had weld work on there LT1/4 intake over the years. I think I have a winner here, time will tell.
jayz28
08-09-2009, 10:43 PM
Where can I place an order?
Looks great and the concept is sound. I'd like to know how it ends up. I'd be interested in trying one out myself.
I_Need_Land
08-09-2009, 10:51 PM
id hav e you build me one also, d1sc right now, f1a soon enough.
T/A KID
08-10-2009, 12:29 AM
Depending on performance, I actually thought about making these. They could be tailored for N/A or FI applications since both setups would like only a few things changed up.
Here is good pic of it on my mock up motor, notice the Throttle cable setup, nice and simple (custom made from stock bracket)
http://i69.photobucket.com/albums/i77/TAKID/DSC01157.jpg
The rear of the manifold accepts the factory fittings.
http://i69.photobucket.com/albums/i77/TAKID/DSC01160.jpg
AChotrod
08-10-2009, 12:32 PM
Thats a bad looking intake!! Let us know how she works!!!
want297z
08-10-2009, 12:33 PM
Hope it works and you make them...Any mods to the cowl area needed for this to fit?
T/A KID
08-10-2009, 12:40 PM
I have not test fitted it, but after all the measurments I have taken, Yes it will fit. Really the only thing that stopped it from being slightly taller was the hump under the cowl. Without that the Plenum could have been slightly bigger.
want297z
08-11-2009, 12:03 PM
I would like to see it after the test fit to see how close it is and to see what the gains are.
Again good luck.
Beaflag VonRathburg
08-11-2009, 03:56 PM
I can't exactly comment on the technical aspects of it, but your craftsmanship is nice. I wish I could TIG aluminum. I have a few ideas on making an intake for a LT1 engine out of the spare parts in my garage even though I don't have an LT1 any more.
T/A KID
08-13-2009, 02:15 AM
Anyone have any valid information on the questions I presented in the original topic?
Ice78Transam
08-13-2009, 09:54 AM
In my experience, plenum volume isn't very much an issue with forced Induction. In my work with turbos we would always use a large, not huge, manifold. Too large (say 120+% engine displacement) theoretically can increase lag time. Intake runner geometry is far more important in my opinion. 'Spider Web' runner set ups seem to work best in my opinion.
Runner length, again, is less important with F.I.
Simply put, when the manifold is pressurized, it will be forced to gulp down as much air as it can, not having to pull it in.
Turbos/Superchargers also prevent the air starvation and inherent rich conditions that result in the cylinders most distal to the Throttle Body.
Really, simplicity and strength count.
As for the N/A applications Larger plenums help mitigate rich running conditions at very high rpm, however too large and air velocity suffers creating turbulence.
Just been rambling in my morning haze. I'll check back in a little while.
Project Looks awesome by the way, should make good Tq. on that LTx!
T/A KID
08-13-2009, 08:16 PM
Ice78Transam thanks for the info, I have been lerking on speedtalk.com for awhile. A lot of people on there that really know there stuff.
Thanks for the compliment, I am hoping we can add a good bit of hp/tq throughout the rpm range. I will tune the car with the LT4 Edelbrock I have at the moment and just do one change, which will be this intake. Will be on the same dyno and hopefully the same day (to make a valid test). Hopefully the car will loose some boost and we will have to add fuel.
Anyone else have any input?
P.S. I ordered some Devcon F epoxy this morning, the intake should be perfect (in my standards) when I get that applied
Beaflag VonRathburg
08-14-2009, 07:45 AM
I was going to suggest you post this on speedtalk, but I see you are already lurking over there.
Speed Density
09-17-2009, 12:56 AM
Any updates on this?
T/A KID
09-17-2009, 02:24 PM
In Grad school, but I have epoxied the intake in areas that needed it. Next is to clean it up some and paint it. Then I'll get some testing Vs my Ported LT4 intake from LE.
Speed Density
09-17-2009, 04:54 PM
Work faster. :thumb:
Beaflag VonRathburg
09-19-2009, 05:37 AM
^ And post pictures.
z_speedfreak
09-19-2009, 11:30 AM
nice work!!! curious to see how it works awell!
what ever happened to the guy(GPCC?) converting & modifying those HSR intakes for LTx's? I know he got banned for some reason but has anyone tried one of those?
T/A KID
09-19-2009, 01:39 PM
I have a good friend who had a converted HSR before GPCC ever started modding them. Good intake from what I have seen. With any intake though, it just needs to be matched with the right RPM range of the motor IMO. Thats when runner length, plenum volume, and cross section come into play.
David_viny
09-19-2009, 10:05 PM
This is a totally different engine, but it should apply universally.
Theirs a page in "Building 4.6/5.4L Ford Horsepower on the Dyno" where they compared running different intakes on a Vortech supercharged 03 cobra motor. They tested the Vortech intake, which is basically a hat on the lower section of the factory supercharger manifold; and also tested the Vortech with a 2001 cobra intake (runner length way longer).
The longer runner 01 intake crushed the Vortech/factory lower intake, from 3,500 - 6,500(redline). It was a steady gain, the short runner never even closed the gap up top. The 01 cobra intake made 74hp and 70ft-lbs over the Vortech/factory lower intake. This was a 815hp engine btw (with 01 intake), at 15psi.
1994Sleeper
09-19-2009, 10:14 PM
Great craftsmanship!! Subscribed.
T/A KID
09-20-2009, 09:52 AM
David_viny interesting info, I wonder what the difference in plenum and csa was?
FASTFATBOY
09-25-2009, 01:45 AM
On A FI application this is not really needed as the blower keeps the plenum full.
This however would be a good NA intake, where plenum volume is more critical.
I would have put a vic/super vic on it with a 4 hole, a hat and called it a day.
I would love to see that intake on a 396 NA engine though.
Send that thing to Larry at Speed inc and let him play with it on his car. SInce he already has numbers on his car.
