Mikey 97Z M6
08-09-2009, 12:05 PM
Well, times are tough these days so a guys gotta do things on a budget. My original plan was to buy some SFC's, but they're around 180. I thought that was a little extreme for some bent up steel. I also need a rollbar, so that got me thinking about buying a welder and doing some of this myself since I have so much free time these days being layed-off haha... :) Once I get a welder, I should break even with the price of "bolt-in" stuff, except now I'll have a welder that I can either sell, which would put me well ahead, or just keep it.
Here's some pics of the custom SFC's I'm fabbing up in my garage. I've got most of the cutting/fitting done, now I just need a welding machine to finish it up. :)
Started off with two 5' pieces of 2"x2" mild steel with 1/8th wall thickness. Thes are going to be STOUT SFC's and only be about 2lb's heavier than aftermarket pieces. The actual length of the SFC's ended up at 45-1/2", but the steel yard would only sell 10' min length. I had them cut it in half for easier transport. Total cost for material, 35.00.
http://i34.photobucket.com/albums/d136/Bowties4evr/Z28/Custom%20SFC/ds-001.jpg
Here's the front and rear subframes that I'll be tying together.
http://i34.photobucket.com/albums/d136/Bowties4evr/Z28/Custom%20SFC/ds-002.jpg
http://i34.photobucket.com/albums/d136/Bowties4evr/Z28/Custom%20SFC/ds-003.jpg
I used a piece of foam core board to mock up the bend and pattern for cutting. The bend makes it line up better, and creates an area on the outside mount that can be welded. Otherwise it would be too tight to get a welder into.
http://i34.photobucket.com/albums/d136/Bowties4evr/Z28/Custom%20SFC/ds-004.jpg
Create a pie notch in the tubing to get the bend. Once it's notched, it bends fairly easy, no special tools needed. I used a hand grinder with a cut-off wheel for all the cutting and it went fairly quick.
http://i34.photobucket.com/albums/d136/Bowties4evr/Z28/Custom%20SFC/ds-005.jpg
Once I had the correct angle, I transferred the pattern to the steel and started cutting. This is a trial and fit situation until it's good. Had to do this several time to get the fit good and tight against the front subframe.
http://i34.photobucket.com/albums/d136/Bowties4evr/Z28/Custom%20SFC/ds-007.jpg
http://i34.photobucket.com/albums/d136/Bowties4evr/Z28/Custom%20SFC/ds-008.jpg
Here's the outside area of the front subframe mount that required the bend to get a welder into. Still pretty tight but should be good enough for a MIG torch head. :)
http://i34.photobucket.com/albums/d136/Bowties4evr/Z28/Custom%20SFC/ds-009.jpg
Here's the clearance from the side. They tuck up real nice under the lip of the bottom rocker panel. Once painted and welded in place you'll never see them from the side.
http://i34.photobucket.com/albums/d136/Bowties4evr/Z28/Custom%20SFC/ds-010.jpg
Here's the rear subframe and the connector. Notice that I'll need to fab up a spacer to fill the gap. Also going to fill the factory gap between the LCA mount and the rear subframe rail that goes over the rear axle. This will add strength and integrity to the entire front/rear subframe and create a stronger mount for the rollbar. I'll finish up the spacers once I acquire a welder.
http://i34.photobucket.com/albums/d136/Bowties4evr/Z28/Custom%20SFC/ds-11.jpg
Shot looking forward. The PS SFC is nearly complete other than welding.
http://i34.photobucket.com/albums/d136/Bowties4evr/Z28/Custom%20SFC/ds-12.jpg
The passenger side is nearly identical as the driver side, but here's a few shots.
http://i34.photobucket.com/albums/d136/Bowties4evr/Z28/Custom%20SFC/ps-001.jpg
http://i34.photobucket.com/albums/d136/Bowties4evr/Z28/Custom%20SFC/ps-002.jpg
The PS hangs down a little further, maybe a 1/2" or so. Still barely noticable once it get's painted.
http://i34.photobucket.com/albums/d136/Bowties4evr/Z28/Custom%20SFC/ps-004.jpg
That's it for now. Hoping to have a welder soon so I can finish it all up. :)
Mike
Mike
