Northwest Classifieds - LS1 DS, 10 Bolt w/3.42, ABS Module
Mikey 97Z M6
08-09-2009, 12:57 PM
Got a few things I need to clear out of the garage:
-LS1 aluminum driveshaft. Needs a new u-joint in the rear. I thought I was going to use this with my 9" so I removed the u-joint for a larger conversion u-joint, then changed my mind and went with an aftermarket DS. Would make a nice backup shaft, or just replace the u-joint and go.
....SOLD....
-Stock 10 bolt from 97 Z28 w/3.42 gears. Leaky front seal but I have a brand new replacement seal and new crush sleeve. Local pickup only. 200.00 as-is, or 275.00 if you want me to install the new seal.
-3 Channel ABS Module from 97 Z28. Worked perfect before I removed it. 40.00 local, or 55.00/shipped.
Pics on request.
Mike
tmoney223
08-09-2009, 01:38 PM
Hey I might want that drive shaft cause I get a vibration when I'm going about80 and it might be the DS.
Mikey 97Z M6
08-09-2009, 01:41 PM
Cool man. Come get it. :)
Mike
tmoney223
08-09-2009, 04:25 PM
I'll let you on fryday when I get paid. If anyone eles wants it before then, then go ahead a sell it.
Mikey 97Z M6
08-18-2009, 12:13 AM
Everything still for sale.....
Mike
Mikey 97Z M6
09-22-2009, 01:43 PM
Up top..... All is still available.
Mike
