10 Second Club - How many of us are on Stock bottem end
V3NOM GTO
08-19-2009, 02:50 PM
Just curious. I am. Prolly makin somewhere around 600-650 at the wheels on the spray (going to the dyno next wed). Post up!!!
Z-RATED94
08-19-2009, 02:57 PM
LT1 here with 31k on the clock. Right around 500rwhp on the bottle.
BLWNV10
08-19-2009, 10:40 PM
I'm on the stock 111k bottom. 10.68@128
dreamls1
08-20-2009, 12:05 PM
i am on stock bottom end 700whp, havent been to the track yet
I am also on the stock bottom end.
SLP 02 SS
08-23-2009, 12:36 AM
Stock Block, Stock Crank with a Standard Bore 346ci.
Pushing OVER 500 RWHP N/A
Just replaced my AFR 225 Heads with a set of ALL PRO LS-2 Heads.
Itching to test this setup. Going to put a few miles on it first and then
it'll be time to DYNO Tune and Track Test it.
Getting it ready for Memphis.... 3rd Annual LSX Shootout
JFM-jr
08-23-2009, 12:04 PM
My LS1 was a stock shortblock and used a GM head to boot. My LS2 again will employ the stock GM shortblock as well and will reuse my heads and cam. I run N/A pump fuel
camscam02
08-23-2009, 04:08 PM
My car is stock bottom end as well.
01SuperSport
08-23-2009, 04:49 PM
Wow it's amazing how much power these engines can handle. I bet more than half of you guys are on the stock bottom end!!!!! :eek2:
VIPERSLYR
08-24-2009, 01:48 PM
Full wieght 3680 with me in it stock motor other than ls6 intake and z06 hot cam it made 511hp 605rwtq not sure what its makin now on the 200 shot went 10.80s on the brakes dam bracket racin dailed the car in at 11.00 passed the 13.90 car I was racin pass felt good didn't wana brake out and it ended up goin 10.80s 1.64 sixty at 121mph car normaly goes 131mph probebly would have went 10.70s or 10.60s six speed tranny on a 325/50/15 drag radial these stock motors rock on bottle or boost
jason02Z
08-24-2009, 04:47 PM
im running stock engine and car..bolt on boost, intake and 317's 10.85 126mph 1.63 60' oh yeh 275/50 radials.
SPEEDYws6
08-24-2009, 08:30 PM
Stock bottom end and heads.
robsquikz28
08-24-2009, 10:19 PM
Im completely stock and slow as hell
pheer
08-25-2009, 04:31 AM
^^^ hey, me too!! :D
98 Silver SS
08-25-2009, 05:51 PM
Stock bottom end here too. Full weight six speed with nitrous.
sleeperstyle
08-25-2009, 06:27 PM
stock bottom end, stock heads- probably 500+ n2o passes, 80k or so on it. 10.31 @ 130 mph. TNT 150 shot. made 500rwhp through a th400 so maybe 600hp or so at the crank.
geovett
09-01-2009, 12:08 AM
stock bottom end here, 1/4 best 10.7 @ 125.....150shot...tnt f1 kit..
02SOMWS6
09-04-2009, 07:23 PM
10.50 @ 130mph stock bottom 100 shot m6.
HitmanLS1
09-12-2009, 01:07 AM
this things can handle a ton of power
Rickys S/C Z28
09-12-2009, 05:40 AM
im stock CI LOl
whywhine
09-14-2009, 10:07 PM
Stock bottom,stock heads,small cam,3500 stall ,stock trans,9 inch 3.90's..200 shot dry ,60 lb,255 walbro..7.50 et 1/8 1.60 60ft 90 mph.... 6.80 et 1/8 1.47 60ft 101 mph all on radials,full wieght car minus ac
