10 Second Club - 10.00 to 10.20 what's your 60'???
SPEEDYws6
08-21-2009, 01:04 AM
List your ET, 60', race weight, and transmission.
Thanks in advance.
BADBOYZ28
08-21-2009, 02:20 AM
I'v gone some 6.50's to the 1/8 which is right about a 10.2 1/4 mile. Best 60ft has been 1.32 60ft but consistent 1.35's or so. Race weight is about 3500 lbs and my transmission is a th-350.
Dragkid1917
08-28-2009, 01:01 AM
1.43-1.46 ish. powerglide 1.82 first gear, 3000lbs, 4600 converter comin out at 3k off the footbreak... 4.56 gears.
ndfrsd6
08-28-2009, 02:12 PM
10.2 @ 130 with a 1.40 60ft /6.4 thru the 1/8 @ 105 .....3090 race weight with a th400 5200 stall
jmill96Z
08-28-2009, 02:20 PM
Mine goes 1.31 at around 3300lbs 10.03 @ 133.8
GMMillwright
08-28-2009, 06:03 PM
10.24 @ 137. 1.502 60 foot with M&H 17 inch DRs. 4L60e with 3800 Vig. Footbraked to 1500. 6.60 @ 106 1/8 mile, IIRC.
Steve69SS396
08-28-2009, 06:49 PM
Consistent 10 teens at 131, sixty foot between 1.39 and 1.45, 3,420 lbs., TH400.
JFM-jr
08-28-2009, 07:08 PM
1.31
10.14@131mph
3000#'s
4l60E (Performabuilt)
Circle D 5K stall
410 gear
helicoil
08-30-2009, 03:41 PM
1.44 - 1.47 60'
10.teens @ 133 mph
3780#
4L60E PY3600
3.70 gear
tals7
08-31-2009, 07:19 PM
10.22 at 134 with 1.58 60ft.4l85e/3000sc yank/s-60 with 4.10.car is full weight plus(3800lbs).stock rims(16 inch chrome)mt drs.
camscam02
08-31-2009, 07:44 PM
1.55
10.1's at 136
th400 of the brake
Tires are absolutely gone. Will go low 1.3xs next time out no problem.
tals7
08-31-2009, 07:50 PM
1.55
10.1's at 136
th400 of the brake
what tires are you running?.
camscam02
09-01-2009, 01:33 AM
Mt 28x10.5. that are hard as a rock,old, and sidewalls completely gone.
going to 28x10.5 stiffs this time around.
BADBOYZ28
09-02-2009, 10:35 AM
1.55
10.1's at 136
th400 of the brake
Whats your race weight if you dont mind me asking?
Pro Stock John
09-02-2009, 03:58 PM
white camaro:
10.008@133
1.38
3300 raceweight
TH400
Fuddle 8" 4800 stall
28x10.5
4.10 gear
shifted at 7000
10.92@123mph NA same day
tals7
09-02-2009, 05:56 PM
white camaro:
10.008@133
1.38
3300 raceweight
TH400
28x10.5
4.10 gear
shifted at 7000
10.92@123mph NA same day how much gas did you use to go from 10.92 to 10.008?.
camscam02
09-03-2009, 01:34 AM
Raceweight is right around 3350(dont know exactly), it should go 9.50's or so once we get everything working right on stock heads.
venom ws7
09-06-2009, 06:42 AM
150shot if I'm not mistaken ;)
