10 Second Club - N/A 402 M6 Vettes w/3.42 gears in the 10's, how'd you hit the magic number?
allngn_c5
08-26-2009, 01:12 PM
Well everyone, I have put a lot of money into my car and finally got her the way I want. I have had a lot of fun on the street but have yet to hit the track to see if she has a 10 second pass in her. What I am looking for is launching techniques, what RPMS you were at, your tire selection, how much PSI, and basically anything that you think will help me hit my 10.999 or better run. Considering its going to be my first visit to the track with the 402 I am just hoping for a smooth launch, 3 clean shifts, and a respectable TRAP. I'll be working with some Nittos 305 35r18's. Was going to start out at 24psi and work my way down. As soon as I get to the track I'll post up. Thanks in advance for any and all tips/advice that I can get.:D
blackls1ta00
08-26-2009, 01:29 PM
ID SAY 22 psi on tires,and powershift the shit outta it doug,lol,good luck
allngn_c5
08-28-2009, 09:35 AM
Wow, I guess once you hit the 10 second club you no longer want to help a tech member out. Thanks for all the advice on launching, etc, etc.
SLOC5LS6
08-28-2009, 01:23 PM
Try searching for a guy named Ranger on here. He has a nice Lauch Technique guide that'll help you Doug. Even Launching moderately you should nail a 10.9 or better at 128-131mph.
allngn_c5
08-28-2009, 01:32 PM
Thanks, I've read those already. I just wanted some other peoples opinions.
venom ws7
08-28-2009, 01:56 PM
IMO With your 3.42 you need a very aggresive launch to lower your 60ft start with 20 -22 psi hold the rpm 4500-5000rpm and slip the hell out of that clutch any lower rpm you wont be able to get anything under 2.0 or 1.9 60ft you already have built rearend so you only need traction and good clutch.
THere is a member here ran 11.0 with 505rwhp Formual with 245-50-16 Nitto with full weight M6 Car too I'll try to find those vids.
With your power I think 10.8@130+mph is very possible.
Good luck Doug and keep us posted.
Hussam.
ndfrsd6
08-28-2009, 02:09 PM
like venom said you'll need an aggressive launch .....5000 or so and slip the clutch but the 18's are going to hinder you as well as the 3.42's but i would get a 17 in mickey dr for sure which you should have no problem running a 1.6 60 with
the 18's i would run 20-21 psi depending on the track
good luck and keep us posted :)
allngn_c5
08-28-2009, 07:20 PM
I appreciate the votes of confidence. I'll definately give your suggestions a try when I go. Working Overtime right now. Also weather has been crappy the last couple of Test n tunes. Hopefully things will get better in the next couple of weeks. Its looking like I am going to have to use a PBL to get the track. (PBL = Personal Business Leave) Work is not granting the use of any vacation time. :( especially one day vac's.
camarorat
09-19-2009, 06:52 PM
did you get that car to the track yet. Don't worry about your 60, just go out and run it and see what your trap speed is, that will give you a good indication as to what the car will run.
airforcemanss
09-21-2009, 02:46 PM
with all the money you spent doug i would pick up a 2step.
btw, do you know where the link is for that launching technique, i would like to read it.
highpockets
09-28-2009, 12:48 AM
I think you may need some stickier tires. The 60s will be the key,thats your 10sec right there.High launch RPMs and ease the clutch,dont dump it.You could powershift it but you better be right on,every gear.I also found that you need to almost ignore the lights and concentrate on the launch technique first.I promise it will make a HUGE difference,I took nearly 4 tenths off my normal times by improving(smoothing) my 60 foots. PM me if you want specifics,see my post on CF drag racing section for details of our last track night.:burn:
allngn_c5
09-28-2009, 05:51 AM
Thanks again. Going to give it a try again on Wednesday 9/30/09 if everything works out. Got a lot of things to catch up on after being out of town for 5 days.
ssam98
10-21-2009, 04:50 PM
I say no, cause 3.42, 18", and need sticky tires. your going to spin to much.:mad:
