Chevrolet Camaro 1967-2002 - Fuel Question
View Full Version : Fuel Question
68 LS2 Camaro
08-27-2009, 03:57 PM
I'm planning my fuel set up right now and found out some 69 camaros had a return line in the tank sending unit. The return in 1/4 inch, would that be sufficient for a return line? I'm running an LS2 with a walbro 255 inline pump and regulator.
davered00ss
08-27-2009, 07:29 PM
Probably get a better answer in the conversion section. :)
:drive:
ParkerTPIz
08-30-2009, 06:18 PM
1/4" is small but it should be ok. if u have any major concens, your best bet is to just run a new line b4 you run into problems later.
Does anyone know the size of the fuel lines of a LS2 GTO or vette? Look into that, that may b helpful
