User Support & Resources - pictures not coming up
View Full Version : pictures not coming up
99monguse
09-02-2009, 11:07 AM
For some reason I can't get pictures to come up in posts. This is my PC at work but my home PC will work just fine! Is there a setting I can change or is it in the firewall?
Exeodus
09-02-2009, 12:08 PM
It is most likely your work internet provider blocking "network storage" site. To double check this, try using google images, search for a image, and see if some or even all of the images get blocked.
99monguse
09-02-2009, 01:37 PM
I did a search in google images and I get pictures
Sharpe
09-02-2009, 02:29 PM
Well, you can try clicking on "User CP" in the upper left, then "Edit Options" on the left a little ways down. Then, about 2/3rds of the way down, there will be "Thread Display Options." Make sure "Show Images" is checked.
JeremyT
09-02-2009, 04:35 PM
That setting should be fine since the OP stated he gets pictures when browsing from home. That setting is "global" on the account, meaning it would apply for all computers the user accessed from. Of course if the OP was browsing while not logged in from home, then that is a different story.
I would suspect a firewall issue myself, but it's best to provide us with a link to a thread where the pictures aren't loading so that we know if it's pictures hosted outside of LS1Tech or hosted on LS1Tech.
01firebird01
09-17-2009, 03:54 PM
where is this "user CP"? im at school and bored and ill get on here to look at post but pictures of the cars wont load its just a small white box with a "X" in it but i can view the picture perfectly on my home computer is there some kinda quick settting that would be on this computer that would block certain images?
JeremyT
09-17-2009, 04:06 PM
The UserCP won't be your issue, but here is the link:
http://www.ls1tech.com/forums/usercp.php
I say it's not your issue because you're getting a broken image (white box with red x). I'm going to take a wild guess and assume you're on a network that has some filtering/blocking and that's why you're not seeing some images.
If it were an issue in the UserCP section, as Sharpe suggested, then you would not see those broken images.
99monguse
09-17-2009, 04:37 PM
You're probably right..now that I think about it my PC at home doesn't do this at all!
