11 Second Club - u think ill hit 11's?
View Full Version : u think ill hit 11's?
mike mlodecki
09-02-2009, 04:51 PM
got a 2000 trans am built 10 bolt with 4:10 gears built up trans and a procharger 7psi and flowmaster exhaust but the car has about 4000lbs with me in it cuz of speakers but most likley taking them out u think ill hit 11's with tht in there? car has car has about 430 rwhp.
Intercooler2
09-03-2009, 12:33 PM
It should with tires and traction. Assuming you have a good converter
mike mlodecki
09-03-2009, 04:04 PM
well its an a4 so i got stock converter stock suspension and the tires it came with.
Blown383LS1
09-04-2009, 09:27 PM
You will need some sticky tires and a good launch to run 11's with that weight.
stangbeaterz28
09-06-2009, 02:42 PM
you will need some suspension too, atleast LCA brackets and bars. id recomend getting some Sub-frame connectors too, especially if yours is a t-top.
99T/AMAN
09-29-2009, 09:53 PM
You will need a convertor, rear suspension, and as said before sticky tires to get there
FiFdYnUtz
09-29-2009, 10:39 PM
id say even with a solid converter you would just need that and tires...but suspension would help too...
mike mlodecki
09-30-2009, 03:32 PM
now the car weights bout 3500 now since i took all my speaker stuff out :) now i think i know i can hit 11's at tht weight. vary it 3450-3600 with me in it i did some other stuff to reduce weight jack and spare tire, backseats, and k-member got a BMR k-member and it dropped weight 53lbs. so i should hit 11's now.
tittan1500
09-30-2009, 04:47 PM
did you take a couple 88" flat screen tvs out to... there is no way you had 500 lbs of speaker junk in your car.
FiFdYnUtz
09-30-2009, 05:02 PM
i still think your going to need some tire at least...stall/tire would be ideal..
NSSANE02
09-30-2009, 07:35 PM
No kidding... Maybe that dude in your avatar was hiding in there somewhere :jest:
SLP IROC-Z
10-01-2009, 09:22 PM
probably going to run out of gear in third with those 4.10s...
mike mlodecki
10-04-2009, 09:02 PM
it was bout 500 lbs each sub was 31 lbs. batteries 1 was 61 1 was 58 and 2 were 14, 2 amps one 23 the other 19, the box was the whole backseat and the trunk total 150lbs, ok it was about 435 roundish bout.
NSSANE02
10-04-2009, 09:24 PM
Damn... what the hell kind of system needs 4 batteries :confused:
mike mlodecki
10-04-2009, 09:41 PM
http://s593.photobucket.com/albums/tt14/MMlodecki/
tht kinda system ha
