Special Edition Vehicles - newbie 97 formula ws-6 owner
View Full Version : newbie 97 formula ws-6 owner
chevyjeff59401
09-03-2009, 10:01 PM
hi guys I recently purchased a 1997 formula ws-6 six speed car. It wasbought at an auction and therefore i have no history on car. Here is what I do know. Someone was installing a rebuilt engine and did not finish. I am in the process of removing the engine and tearing it down to clean and inspect. This is necessary due to it sitting in a tow lot with no intake installed. Here is a list of parts that I know are missing. I will update list as i find out more or purchase parts. If you have any of these parts available at a reasonable price and are willing to ship to montana please let me know. I might not be able to purchase immediately so please bear with me. thanks
So far what i know about engine is that it has brand new trickflow heads. electric
waterpump, ati dampner, and a canton oilpan. Also has hooker coated longtubesthe ones where number one cylinder is slip in to clearance steering coupler. Came with aluminum comp 1.6 rr's Motor is out now but not tore down when i get inside of it i will update specs.
1) pcm. i fully realize I will need to pay to have it programmed for my specs.
2) Intake to work with tfs heads
3)throttle body 52mm or 58mm brand not important
4) fuel rail and injectors to work with aforementioned set-up.
5) lifters and spider including locks
6)pushrods
7) air intake system including maf.
8) shifter handle and knob pic available in case shifter is not stock.
9) passenger side hard brakeline.
10) electric fans
Any knowledge and assistance in helping me assemble this car is greatly appreciated. I understand some parts are probably better bought new. So any advise on where to purchase and part numbers would help alot. I am in Montana and the lt-1 guys are few and far between.
thanks Jeff
chevyjeff59401
09-10-2009, 02:39 PM
UPDATE. got the engine out and heres what i found.
1) heads are marked tfs-sbc 7 look heavily ported i will measure valves and post.
2) pistons are srp p/n 138094
3) rods have 4078 and 517800 they are h-beam and screwcap
4) crank has sunrey on it as well as s52, sm13 and 5081 which is stamped
5) the block has black splayed 4bolt caps installed
as I tear down the shortblock I will be sure to add any additional part numbers
everything is new unfired only bad I found is that water got down in it seems to have completely eaten away oil pickup and damaged pump. Doesnt look like it hurt anyting else.
any advise or input is greatly appreciated.
Thanks Guys Jeff
