Stereo & Electronics - Installing a system in my 02 Z28
View Full Version : Installing a system in my 02 Z28
Nate02Z28
09-04-2009, 02:39 PM
So I have a new head unit, sub, and amp that need to be installed. I'm kind of a new to car audio stuff so I'm trying to decide between doing it myself or getting it done professionally.
Basically I want to know how I should connect the sub and amp to the new head unit.
The sail pannel subs are blown out and barely work so how should I go about disconnectiong those? Should I disconnect them from the amp?
I appreciate the help guys, I've been hitting up this forum ever since I got my car a month ago and just decided to join.
94'BLKBRD
09-04-2009, 04:43 PM
Replace the sail panel speakers. You want to disconnect the hatch speakers when adding a sub, not the sail panel speakers.
What sub/amp combo did you go with?
Nate02Z28
09-04-2009, 07:48 PM
The sail panel speakers are subs though in the monsoon aren't they?
Why would I want to replace them with weak subs when I'll have two 12"s in the trunk?
94'BLKBRD
09-05-2009, 12:06 AM
Yes, they are subs.
Replace them because they are blown. If they were good I would say leave 'em. I haven't replaced mine since they're still good and I have 2 10's.
Nate02Z28
09-05-2009, 03:39 PM
I don't understand why they are needed though. They would only put out weak bass which would be drowned out by the larger subs.
Seems like a big waste of money and I'm on a tight budget.
JackArse32
09-05-2009, 07:25 PM
when you replace them, since you are putting in a seperate sub, you need to replace tehm with a 2 or 3 way type speaker. for your rear fill. not with a midbass driver.
Nate02Z28
09-07-2009, 05:33 PM
For now I'll just have to live with the hatch speakers and my door speakers.
Eventually I'll have the whole car rewired for new speakers.
But good bass is all I need to be happy for now.
My setup has changed though I decided not to use the two 12"s but instead get one good 12" in a little box.
My plan is to put it right behind the back seat facing up and slightly angled back facing the hatch.
Does this seem like a good idea or a bad idea? Is there any reason I wouldn't want to do this?
JackArse32
09-07-2009, 07:06 PM
i wouldn't see an issue with it. in fact, with only using the hatch speakers in the back, it's probably better that way. it'll be a bit more balanced with 1 12, rather than 2. just a question of what you're going for. boomy, loud bass, tight controlled bass, sound quality, or.. i jsut want others to hear me. haha!
Nate02Z28
09-07-2009, 11:14 PM
Really I'm looking for a combo. I like a lot of bass but I like quality where I can still hear the rest of the music.
For now I'm leaving all my other speakers stock until I can afford to rewire the car.
Another question I have is what will I need to install the sub amp and head unit, as in adapters and mounting and stuff?
