User Support & Resources - ls1tech mobile setting?
View Full Version : ls1tech mobile setting?
my bandit
09-04-2009, 05:46 PM
i just got my blackberry today and when i went to come on here it would not allow me to switch to the mobile version. i have a sprint blackberry curve. am i missing something?
Sharpe
09-04-2009, 06:03 PM
The mobile "style," as listed in the drop-down menu in the lower left hand corner of every page?
Otherwise, there are two threads on the front page of this forum about LS1Tech's mobile support:
http://www.ls1tech.com/forums/user-support-resources/1158234-ls1tech-app-iphone.html
http://www.ls1tech.com/forums/user-support-resources/1162117-when-will-there-blackberry-smartphone-ls1-app.html
my bandit
09-04-2009, 06:09 PM
i know that. is there something more i have to do or do i just click on it? when i chose it it didnt do anything. it stayed the same way as the default setting is
streetassasin
09-04-2009, 06:16 PM
It works just fine on my storm
JeremyT
09-04-2009, 06:43 PM
Make sure that javascript is enabled. That menu option requires javascript be enabled, which can often be disabled on mobile phones. What you describes sounds like javascript is disabled in your mobile phone browser, which makes the menu not work.
You could always bookmark the following link on your mobile phone:
http://www.ls1tech.com/forums/index.php?styleid=23
The above link will take you to the mobile version, and is cookie based. This means that whenever you browse with your mobile phone, if you use the link above, you'll see the mobile version. However, when you then browse on your desktop machine, you'll see whatever version you had previously been using.
Use this link if you need to go back to the "default" on your mobile phone:
http://www.ls1tech.com/forums/index.php?styleid=19
But if you want to make the drop-down menu work, and other features on this forum work, you need to enable javascript in your mobile phone's browser.
my bandit
09-04-2009, 06:47 PM
thanks. i just couldnt figure out why i would click on the mobile setting and it not do anything
