Blackbird
09-05-2009, 01:09 PM
been searching but cant seem to locate the instructions.
would like to see what is involved in case I need to tackle this myself.
this would be for a formula.
TIA
my bandit
09-06-2009, 11:58 PM
alright this is what i did. make sure you have the radio with you it will make it alot easier to line up.
1. get a piece of thin plastic (i used plexyglass and cut out the right size to fit on the radio)
2. remove bezel, measure out the area to cut off with the plexy glass. then attach the plexyglass to the back of the cut out.
3. use something to fill in the area to make the new sides. i used this stuff called marine tex. once you let it harden, sand it down and fill it in with bondo. sand that down and paint. (remember to fill in the little slot between the radio and the ac controls)
i did not have to relocate the ac controls and did slight cutting to the dash (just the little tabs up under the vents and the bottom tray)
here is what my install looks like
http://www.ls1tech.com/forums/appearance-detailing/1173052-my-double-din-install.html
if you have anymore questions just ask me. i will try to help you out
6LITEREATER
09-09-2009, 03:51 AM
I sell an ABS version for $75 on my site if you don't want to go through the hassle...
www.6LITEREATERDESIGNS.com
