Pontiac G8 2008-2009 - track time
black widow g8gt
09-05-2009, 07:24 PM
ok i ran my g8 gt last nite for the first time i ran a 14.4 and then a 14.3 both at 100 mph i dont know what the problem is or what yea i live in south texas and it was high humidity and around 90 degrees outside does that have anything to do with it or what? help me out too slow..
Cyris0014
09-05-2009, 08:34 PM
60 foot?
04BlackGmc
09-05-2009, 08:47 PM
track condition weather Da all have a huge part in it...
black widow g8gt
09-06-2009, 02:00 AM
the 60 foot time for the 14.3 was a 2.234 and for the 14.4 was 2.257 and help?
Blackbirdws6
09-06-2009, 09:00 AM
you will be in the 13's if you get that 60' down to a 2.0. I've run a 1.96 60' with the stock 19" potenza's for reference. Sounds like it was a hot and humid which also hurt your times.
adanieljohnson1
09-06-2009, 10:50 AM
Whats your elevation?
black widow g8gt
09-06-2009, 04:41 PM
dude were so low down here damn near sea level. so what would get my 60 foot time better would the vararam intake help that? cause ima wait to get a tune.
black widow g8gt
09-06-2009, 04:42 PM
should i power brake off the line of jus put it down when the tree hits green?
itsslow98
09-07-2009, 01:10 AM
definetly power brake as much as you can withoutout spinning. this should should get you to a 2.0 without any money.
Blackbirdws6
09-07-2009, 10:09 AM
Depends on the car. Stock G8's seem to like being nailed off idle as when you try to stall them, the TQ management is very intrusive.
Devilish34
09-07-2009, 11:32 AM
My best 60' on stock 18s with RSAs is 1.94. Loaded to 1k with a 1/4 tank or less gas.
That was with a DA around 1800
04BlackGmc
09-07-2009, 01:01 PM
my 1.98 was done launching off idle...stock 19's at 34psi
familycaronROIDS!
09-07-2009, 01:48 PM
My best 60' was 2.216 - 1/8 8.8 - I havent tried on Idle I will try that next. 60' ft on
G8's are usually bad - I've seen some guys do a 60' 2.+ and get 12's on the 1/4 mile?? weird!! The numbers on these 4 door monsters are weird it all depends on your mods.
1/8 mile tracks do these cars no justice unless you have gears/converter/street slicks.
black widow g8gt
09-07-2009, 06:43 PM
aite well thanks guys i guess i will jus play with it this friday at the track i jus dont understand why i would run a 14.3 when i have already put the full corsa exhaust on it that comes with the x pipe and stuff i jus dont know why i am not in the thirteens.
svede1212
09-07-2009, 07:59 PM
i suspect that just as with a GTO a catback isn't doing anything for you and is just an expensive sound mod until you get a lot higher up in HP. get a tune and on a cooler night you'll be in the 13s
itsslow98
09-08-2009, 12:48 AM
sorry i just firgured that just about all cars launch better if you power brake a bit. try a few different things out youll find the right thing and be set.
ScreaminRedZ
09-08-2009, 08:58 AM
Yeah, I've heard that the caback doesn't do much performance wise on a stock car. I'm probably going to do headers back to the axleback pipes and leave thse stock. I want the performance and a good sound, but not obnoxiously loud.
Patrick G
09-08-2009, 09:26 AM
aite well thanks guys i guess i will jus play with it this friday at the track i jus dont understand why i would run a 14.3 when i have already put the full corsa exhaust on it that comes with the x pipe and stuff i jus dont know why i am not in the thirteens.Unless you have a full engine and tranny tune, you're leaving at least a half second on the table in ET. You would be amazed how much timing is pulled at the starting line. The tune on my G8 made a night and day difference.
amadeospike
09-08-2009, 02:38 PM
I ran my car with stock tune numerous times in hot humid weather in edinburg but it always ran 13.9 or better. After like 5k and a tune it dipped into 13.2x. If your going to the track in edinburg hit me up and i can check it out for u so u can see exactly what's going on with the scanner. I suspect your torque management is holding u back. Try using the paddle shift mode that sometimes helps.
98Aggie
09-08-2009, 10:51 PM
need to bring the car down to Victoria and let Patrick tune it for ya. I have ridin in his and it is quite a different car when you punch it.
black widow g8gt
09-09-2009, 01:18 AM
how much does patrick charge for the tune and how much for re tunes? i jus dont get it. isnt this car supposed to run mid to high 13s stock could it be cause i am runnin 87 octane? If i run one tank of 93 to run this weekend would it mess it up if i went back to 87 next time i fill up?
Darracq
09-10-2009, 03:39 PM
Mine ran 13.70s with a 2.08 60 just off idle, traction controll on. 1800 DA
familycaronROIDS!
09-10-2009, 03:48 PM
you would probably do a 13.5 with the traction control off. Did you run on Sport mode or Drive.
black widow g8gt
09-10-2009, 04:47 PM
yea if i run in sport mode where exactly should i shift at?
familycaronROIDS!
09-10-2009, 10:10 PM
bone stock and/or a tuned with basic mods CAI exhaust - Drive w/ tc off gives you better results - dont base your self by sport mode having higher RPMs. I thought the same but when I tested Drive vs Sport mode tc off - same day same track w/ 20 mins in between (3times each mode) Drive w/ tc off was 2 tenth faster in the 1/8 mile.
javier1551
09-17-2009, 04:56 AM
At the same track (edinburg) I ran a 13.2 bone stock on my GXP. I cant wait till patrick gets a hold of it and tunes it to see what it will run. Plus my headers and CAI just came in so this should be a little interesting...
09gtt
09-17-2009, 06:42 AM
If it's in sports mode it should shift automatically for u. Tune n vararam turn it into a completely different car. Practice also helps.
Devilish34
09-17-2009, 08:37 AM
There are plenty of stock G8s that have run mid 13's .
black widow g8gt
09-17-2009, 07:12 PM
yea i thought it would shift automatically also cause that is how my chrysler was but it doesnt if u dont shift up it doesnt shift. are they all like this or is mine messed up?
Devilish34
09-17-2009, 10:06 PM
Did you put it in Manual or Sport?
black widow g8gt
09-17-2009, 10:23 PM
whats it called when i move the shifter to the right and shift it myself?
09gtt
09-18-2009, 02:22 AM
When u just move it over to the right it is in sports mode. If u move it to the right n tap it up or down that's manual mode. I would just use sport mode when ur at the track. Just move it to the right and don't tap it up or down. That will leave it in sport mode where it shifts for u.
black widow g8gt
09-18-2009, 07:43 PM
yea man i was messin around with it yesterday to try and figure it out and i got it. i am gonna do one run tonite in sport mode and one run in manual shifting at 5500 rpm.
Devilish34
09-18-2009, 11:38 PM
Slow Mode
black widow g8gt
09-19-2009, 01:46 AM
well i ran tonight i ran a 14.127 at 101 mph and the 60 foot time 2.187 in sport mode and i ran a 14.029 at 102 mph 60 foot time 2.129 in manual mode still kinda hot and humid was around 82 degrees do you think i could get a 13.9 when a cold front comes in and i will have my vararam intake then also?
black widow g8gt
09-21-2009, 07:41 PM
any input fellas?
familycaronROIDS!
09-22-2009, 11:26 AM
My fastest times have come on regular Drive T/C off and power braked and launched at 1300rpms. As for me I think its about 2 tenths faster on regular Drive than Sportsmode. It feels stronger because the RPMs are higher but it doesn't do anything if you are stock or has minor mods.
Drop your tire pressure to about 28psi (rear tires only) - regular Drive T/C off & launch at around 1200-1300 rpms - 1/4 tank of gas only
Devilish34
09-22-2009, 09:34 PM
What was the track DA?
black widow g8gt
10-08-2009, 05:59 PM
ok so i ran again last night i am happy with my time does anyone think it should be better or is it average? 60 foot 2.110 E.T. 13.927 at 103.613 please let me know i would like to hear what yall think about this time...
Patrick G
10-08-2009, 11:26 PM
ok so i ran again last night i am happy with my time does anyone think it should be better or is it average? 60 foot 2.110 E.T. 13.927 at 103.613 please let me know i would like to hear what yall think about this time...I think you'll be amazed how much power you pick up with a tune.
04BlackGmc
10-09-2009, 12:18 AM
indeed..
jrgswhitels1
10-09-2009, 04:56 PM
There are many factors that contribute to track times. Probably the most notably factor here, short of elevation, is the barometric pressures of the night. Take note!!
javier1551
10-09-2009, 07:03 PM
Hey jacob if the rain holds run it tonight so you can hit that mid 13 I am sure that you can hit it.
black widow g8gt
10-10-2009, 09:53 PM
i know bro we will catch it on a good day this winter no worries. i am looking to get the intake hsrk and under drive pulley. i am trying to see if they void warranty first though..
JDMC5
10-22-2009, 01:07 AM
work on that launch a little more and wait for better weather, you should be able to click off a 13.7 or faster....not bad for a stock car. These guys are right though, a good tune will easily knock off another 3-4 tenths. Think about getting an air intake too.
