Convertible Vehicles - Anyone go the manual top route?
00Camary
09-09-2009, 03:54 PM
OK thanks a lot guys for the direction in doing this. Let me just say that if you have the tools and you can turn a wrench you can remove this whole system within a matter of < 2 hours. Probably saved 20 lbs and it is really easy to put back in too.
LS1_Fonzie
09-09-2009, 05:30 PM
One guy on here that did it said that if the car is a daily driver and you enjoy putting the top down that it wasn't worth it to remove the motor and hydraulics. It saves around 15-20 pounds. I'm not sure how easy it is to drop and raise the top after the motor is removed but I would think it that it wouldn't be that difficult to do. If you decide to do it though keep us updated, I would like to see what goes into doing this.
00Camary
09-10-2009, 07:35 AM
I hear ya.....hmmmmmmm
eseibel67
09-10-2009, 09:10 AM
I don't have any hydraulic issues or the need to reduce weight, but I've also thought about this.
My guess is that if the cylinders are removed, the top would be very easy to raise or lower manually.
jimmyblue
09-10-2009, 10:31 AM
If you like crawling over the back seat, maybe. My
first convertible was a Fiat Spider and that one, I
could just lean back, grab and pull. But there's an
extra 2' or so here and you'd need orangutan arms
to do that from the driver's seat. Plus this top is a
whole lot more meaty, longer and more stout.
And you ought to see the scissor-frame top on
my 20'-long '75 Caprice....
I think I'd be leaving the hydraulics alone.
Devils Mentor
09-10-2009, 08:24 PM
Talk to the 3rd gen guys! All 3rd gens were manuals. I would comment, but my 3rd gen verts were Autoform hard top convertible 2 seater roadsters - COMPLETELY different.
GL!
DM
00cls1camaross
09-11-2009, 04:11 AM
It isn't hard, i have been doing this for over a year now.
It is quicker than doing it with the button.
The only bad news is it makes you look like a bitch if you are putting that thing up and down manually. I never put it up and down in front of girls... So i leave it down 98% of the time.
SlickVert
09-13-2009, 11:37 AM
Works great.
You unlock it form the inside and while standing outside next to the car, you just lower it.
To raise it you repeat the process in reverse.
Bob
Johnny-LT1-runner
09-13-2009, 04:47 PM
I have my hydraulics turned off because it's easier to do it manually. It literally takes 2 seconds compared to what, 10-15 seconds with a switch?
00Camary
09-14-2009, 08:03 AM
Huh.... Well i am going to look into doing some lightening then. Does anyone know what the whole delete will weigh out at?
98Bird
09-15-2009, 03:56 PM
I would sell the convertible and get a hard top if you care that much about weight for racing. Plus, you'll have a more rigid structure vs. a vert.
It's crazy to go manual top b/c they were made to operate with a motor, and should be heavy as hell w/o it. I'm in really good shape (jog at least 6 miles per week and 4-5 days of MMA training)....but lifting up the top for my old Mustang 5.0 that had a bad motor was tedious and hurt my back after a few months. I tried to keep the top down all day in order to avoid putting it up & down. The interior got rain bathes at least 10x from this.
It's very heavy. If you lift it on one side while standing, it stresses the 'vert frame, glass stictching/glue, etc. and your back and you'll eventually have back pains. The best way (which I later figured out, but back already hurting) was to climb into the rear seats and squat at the middle, facing front and arching backwards to grab the top at the middle and lift it over your head. Going through this crap defeated the whole purpose of enjoying a convertible.
It's not like a Miata's top, where you can raise & lower it with one hand.
00Camary
09-15-2009, 04:02 PM
Have you done it with a fbody vert? Was the linkage still in tact in the 5.0? maybe thats why it was difficult.
Johnny-LT1-runner
09-15-2009, 05:18 PM
News Flash!!! These are Camaros not mustangs nor miatas! :eyes:
And you CAN do it with one hand.
Maybe you're just not as strong as you think?:confused:
eseibel67
09-15-2009, 05:19 PM
Yes, he must be pushing against the hydraulics.
00Camary
09-15-2009, 05:22 PM
Thats what i was thinking. I might really have to try this.
How much do all of the pump accessories weigh?
taws6m6
09-24-2009, 05:31 PM
I have had mine out, all the hydraulics, pumps, lines etc out for a while now. If you can't stand outside the car and raise and lower it with one hand something is wrong. you don't have to climb in the back seat like others say, unless you're a weak little girly man. the whole assembly doesn't weigh much, the motor is the heaviest piece, the hydraulic pumps are light as hell
00Camary
09-25-2009, 07:56 AM
hmmmmmmm.... more confirmation. Thanks for all the imput. :D
00Camary
09-29-2009, 09:19 AM
Okay i took some stuff apart in the trunk and i have found the pump. I kinda stopped there and ask the people in here how they went about removing everything. Is it possible to leave the system complete so i wont need to bleed lines if i ever install it again? Where are the piston cylinders? I assume in the rear panels right?
eseibel67
09-29-2009, 09:58 AM
Likely have to open the system to remove the individual components. I'm sure those little hydraulic lines go through a hole somewhere that the cylinders wouldn't fit through.
With the top 1/2 down, you can see the cylinders in the 1/4 panel.
taws6m6
09-30-2009, 02:59 PM
It CAN be taken out as a system. Just unbolt the pump, trace the hydraulic lines around and take off the clips here and there holding them down. Now, the pump, its been a while, you may or may not have to take off the 1/4 panel. There is a steel pin, along with a cotter pin holding them in, take that off. I really cant remember if there are any bolts at all holding them in, seems like there was one, and there was also a hole in the sheet metal for access. I took mine out as one whole assembly, never drained anything, my pump still has fluid in it right now. All it is the pump, some lines and the cylinders, not much to it at all. Oh, and do it with the top up, that way you can get to the inside of the quarter panel, you may or may not have to slightly raiser the top to gain access to them. Aint shit to it
00Camary
09-30-2009, 03:19 PM
Kewl.... i will look into it. :) Man this site is great for this type stuff.
00Camary
11-01-2009, 05:09 AM
Took it out yesterday and it was easy to do. It will be just as easy to put back in as well.
Came out as a complete system and no need to drain anything whatsoever.
eseibel67
11-01-2009, 07:12 AM
How much effort is involved in raising/lowering with the hydraulics removed?
Estimate on weight of the whole system?
00Camary
11-01-2009, 05:10 PM
The top is fairly light and you can raise and lower it with ease.
Probably only about 20-25 lbs of stuff though.
You from Ontario?
