Tools & Fabrication - Bypass for the coolant line under intake? HELP!!
Redta00
09-14-2009, 01:19 PM
Does anyone know if there is a way to fashion some kind of bypass or something for the coolant line that runs under the intake on an LS1? I am installing a Fast 90 and having clearance issues so it has to come out, but I don't want to spend the $75 to by one from TSP or Ebay. Thanks for any help.
01ssreda4
09-14-2009, 02:36 PM
I don't think you can just bypass it completely. I don't understand why you have a high dollar intake but won't buy the kit you need to install it.
Redta00
09-14-2009, 03:05 PM
Honestly it is more that I don't want to wait for the part to come in....the car has been down for two weeks and I want to get it running and take it to the track this weekend. Figured if there is a way to rig it for now then I would do that.
Randy WS6
09-14-2009, 09:56 PM
I have the rear cross over ports blocked off and the front is crossed open, Use the LS6 intake cross over kit, It deleates the rear and only feeds the front.
Or take your stock pipe and cut the ends off and seal them with weld or epoxy and cut the Y out of the front that goes under the intake and have it welded up. Easy to do, If you cant fint some one to do it , send it to me and i can. Just pay for the shipping
Redta00
09-14-2009, 10:07 PM
What is the back line for if it can be removed? I have heard that it was an easy fix and it sounds like it is. The part that crosses under the front of the intake will not be a problem as far as clearance? Thanks again for the help!
Ping King
09-14-2009, 10:13 PM
ill trade you my ls6 style for your ls1 style.
Redta00
09-14-2009, 10:22 PM
I would man but I want to get it back on the road before the weekend. BTW does the LS6 line really look that different? Pic handy?
Randy WS6
09-14-2009, 10:49 PM
Hers a pic i found
http://cgi.ebay.com/ebaymotors/New-GM-OEM-LS6-Coolant-Crossover-Pipe-Kit-LS1-LS2_W0QQitemZ290349321958QQcmdZViewItemQQimsxZ2009 0913?IMSfp=TL0909131310005r6469
Big_Bird_WS6
09-15-2009, 02:50 PM
if you get reading. there have been a few of us that have questioned the whole "delete" the rears or not. 7 and 8 cyl always are the first to go. what if it is cause of streem pocket back there?
so i bought 4 of these (http://s41657.storefront-solutions.com/detail.aspx?ID=3289) and then going to hook them all together.
