boostedbuford
09-14-2009, 11:44 PM
It ran the times in the sig w/a 1.79 60' and shitty nittos on a 17'' rim, now it has the current set-up as listed below.
What kind of 60 do you think I could get out of it?, 150 shot predictions? Times on Motor?
Mod's...
ENGINE
-(Xtreme Horsepower)XHP 347 Forged shortblock
-Stock GM Crank
-Eagle H-Beam 6.125'' Rods
-Forged Mahle pistons
-ARP 8740 Rod Bolts
-APR Main bolts
-Clevite77 Race bearings
-Fast 92mm Intake
-PTM 92mm Throttle body
-Patriot Stage 2 Heads
-F14 cam (232/234 598/601 112)
-XHP LS 7.4 Pushrods
-42lb. Injectors
EXHAUST
-TSP 1 7/8 Ceramic Coated Long-tube headers
-TSP 3in ORY
-Hooker Cat-back- Corsa Tips
-QTP 3in electric cutout
TRANSMISSION
-Performabuilt Stg 2 trans.
-Performabuilt 9.5 Lock-up 3600 convertor
SUSPENSION-
-UMI Tubular K-member,
-UMI upper and lower A-Arms,
-UMI Weld-in Sub frame connectors
-UMI Lower Control Arm's,
-UMI Adj body mount tq arm,
-UMI Pan hard bar, 32/19 ss swaybars,
-QA1 12-way adj shocks/ 275lb. springs
-V6 Rear springs
-Passanger side rear Drag-bag
WHEELS/TIRES-
-15x8 Weld Prostars
-15x4 Summit stars up front
-275/60/15 Mickey Thompson D/R's
-Kuhmo 165/70/15 skinnys
REAREND
- Built 10 bolt, upgraded internals, TA girdle, 3.73's
Mod's...
ENGINE
-Stock GM Crank
-ARP 8740 Rod Bolts
-APR Main bolts
-Fast 92mm Intake
-42lb. Injectors
EXHAUST
-TSP 3in ORY
TRANSMISSION
SUSPENSION-
-V6 Rear springs
WHEELS/TIRES-
-15x8 Weld Prostars
REAREND
