alan2000T/A
09-19-2009, 10:36 AM
SOLD, THANK GOD!
For Sale:
New never rolled on Greg Weld Racelites 15x3.5 fronts, 15x8 rears with tires.
-front backspace 1.75” backspace
-rear backspace 5.5”
-dual bolt pattern 5x4.75 and 5x4.5 (chevy & ford)
-brand new wheels, 0 miles
-brand new front tires, 0 miles Nexan 165r15
-everything bought this month except rear tires
-rear tires Mickey Thompson ET Drag Radial 275/60-15 (12 passes old, no street miles)
-new open end shank lugs w/ washers
-center caps included
-fronts are direct fit, rears are not. Will not fit ls1 rear brakes, fits lt1 with major grinding. Only way to fit properly would be those w/ rear drag brakes or non 4th gen f-body. I was not comfortable with the amount of grinding needed to fit 4th gen f-body brakes, which is why I’m selling. Would be awesome for drum brake cars or earlier f-bodies/gm cars w/ 5x4.75 bolt patter/5 lug mustangs/fox bodies
Notes For 5x4.75 in. bolt pattern use centered lug nut washers; 5x4.5 in. bolt pattern use offset lug nut washers.
Wheels engineered to deliver performance style that will impress from Greg Weld.
Greg Weld has used their 50-plus years of hard-core racing experience to offer wheels on a level above the competition. These Greg Weld Racelite series 93 Prolite wheels feature a new design called HDA (High Density Alloy) technology. This is the result of state-of-the-art manufacturing processes, engineering, and precise planning. The process creates one-piece cast aluminum wheels that are lighter, stronger, and truer. Greg Weld Racelite series 93 Prolite wheels have eight oval-shaped unique holes and use a bolt-on signature Greg Weld center cap. The unrivalled engineering and design of these wheels makes them the perfect choice for your street rod, race car, or daily driver. Available in your choice of chrome plated or polished finishes, Greg Weld Racelite series 93 Prolite wheels will definitely set your ride apart from the crowd.
Big loss at $750 for the whole setup, $550 w/o rear tires. email at blessedbanker@hotmail.com (check from blackberry)
http://img183.imageshack.us/img183/8715/gregweldnew15x3415x8fla.jpg (http://img183.imageshack.us/i/gregweldnew15x3415x8fla.jpg/)
Driver side front 1
http://img84.imageshack.us/img84/9140/gregweldnewdriverfront.jpg (http://img84.imageshack.us/i/gregweldnewdriverfront.jpg/)
Driver side front 2
http://img44.imageshack.us/img44/6690/gregweldnewdriverfronti.jpg (http://img44.imageshack.us/i/gregweldnewdriverfronti.jpg/)
Driver side rear 1
http://img34.imageshack.us/img34/301/gregweldnewdriverrear.jpg (http://img34.imageshack.us/i/gregweldnewdriverrear.jpg/)
Driver side rear 2
http://img34.imageshack.us/img34/3672/gregweldnewdriverrearii.jpg (http://img34.imageshack.us/i/gregweldnewdriverrearii.jpg/)
Passenger side front
http://img34.imageshack.us/img34/9649/gregweldnewpassengersid.jpg (http://img34.imageshack.us/i/gregweldnewpassengersid.jpg/)
Passenger side rear
http://img34.imageshack.us/img34/8970/gregweldnewpassengersidw.jpg (http://img34.imageshack.us/i/gregweldnewpassengersidw.jpg/)
Passenger side
http://img34.imageshack.us/img34/1323/gregweldnewpassengersidq.jpg (http://img34.imageshack.us/i/gregweldnewpassengersidq.jpg/)
For Sale:
Driver side front 1
Driver side front 2
Driver side rear 1
Driver side rear 2
Passenger side rear
Passenger side
