Pontiac GTO 2004-2006 - anyone with a hendrix clutch kit ?
maxspeed96ct
09-19-2009, 06:16 PM
Hey if you have a hendrix clutch kit.
What slave cylinder are you running?
Stock ls1 slave or ls2 slave work ok ?
my first GTO
09-19-2009, 06:17 PM
We have install alot of Thomas's Clutch's with NO problems and use the f-body slaves.....Frank
maxspeed96ct
09-19-2009, 08:51 PM
K so from what I understand the f-body salve and ls1, ls2 GTo slave is the same in size correct?
Im installing a hendrix clutch on my CTS-V and from the info ive gatherd I should be able to run a F-body slave and just switch my connection lines.
my first GTO
09-19-2009, 10:18 PM
Yes you can....Frank
bravoboost
09-21-2009, 12:48 AM
Hendrix clutches are the shit ! BTW ....Made about 750 crank without showing any signs of weakness from the clutch
