Pontiac GTO 2004-2006 - Gto stock stall ?
GTOTKO
09-23-2009, 01:42 AM
what size stall doea a gto have stock and if i wanted to put a 232/238 cam in it what the minimum size stall i could use to keep it from dying out ?
breze84
09-23-2009, 02:04 AM
Im not to sure what the stock stall on a goat is, but if I were to guess I would say maybe a 1500 or so.... If I were to upgrade the stall, I would go with a 3500....
mark21742
09-24-2009, 05:10 AM
I'm running a 3,800 in mine and love it! don't forget if you do a stall you NEED a tranny cooler, and I'd highly recomend the beast sunshell and a shift kit
batboy
09-24-2009, 08:47 AM
Think the stock converter is about 1800 RPM stall. For the cam you listed, minimum stall would be 3000-3200 RPM.
teblmb
09-25-2009, 02:05 AM
for sure go 3000 +
GTOTKO
09-25-2009, 02:34 AM
ok i drive this car alot as long as im not beating on it too bad and have a shift kit and trans cooler ill be ok with a 3600 stall or 3000 ?
StealthFormula
09-25-2009, 10:34 AM
Yeah, tons of people running stalls like that or larger all the time. I took out my tranny with 15,000 original miles and a 3600 stall but I seem to be more unlucky in the trans department than most others. With a proper sized trans cooler the life of the transmission will be greatly extended vs. running no cooler.
GTOTKO
09-26-2009, 04:07 AM
ok any aftermarket size cam i can run with a stock stall ? j/w
batboy
09-26-2009, 10:02 AM
I ran a Thunder Racing 224 cam for a year no problem with a stock converter. That's about as big as I would go before getting a higher stall converter though. I now have a 2800 RPM stall with that same cam.
GTOTKO
09-27-2009, 03:10 AM
how much power could i get with that cam ?
batboy
09-27-2009, 10:56 AM
About this much power:
http://videos.streetfire.net/video/2004-GTO-drag-race_159823.htm
GTOTKO
09-27-2009, 02:55 PM
nice thats definately not bad i think thats the way im gonna go
batboy
09-27-2009, 09:18 PM
I also had 243 heads on the car in that video (and of course a tune). You can sometimes find 243 heads (off a LS2 or LS6) for $400 to $500.
