Pontiac GTO 2004-2006 - Longer Wheel Studs?
TARZAN
09-23-2009, 10:46 PM
Ok, are there any options worth talking about aside from ARP? Thats not cheap if you wanna replace all 20.
Part #'s?
Thanks,
-Will
sftaws6
09-24-2009, 12:20 AM
They weren't that bad from summitracing.com for the rears. I think it was $13 for each side. ARP-100-7708 that's the part number. The fronts are a liitle more but not to much. IMO
svede1212
09-24-2009, 04:50 PM
the fronts are a lot more. they'll set you back $72. the only ones that fit are ARP 100-7717 for an EVO. those fronts are hugely long but you will probably need to cut both the fronts and the backs. strangely the stock GTO studs for the front and the back are also two different lengths with the backs being shorter. IMHO the backs are well worth replacing both because the stock ones are short and are soft not to mention they aren't too expensive either. i've done all four wheels as besides that i have 5mm wheel spacers on all four wheels, the backs to adjust for the widened wheels and the fronts to give me more camber.
TARZAN
09-24-2009, 05:10 PM
No plans on cutting them, just sounds like a bad idea to me.
-Will
massillongoat
09-25-2009, 02:14 PM
summit mosers...there cheap thats what I bought
Gregory
09-27-2009, 12:11 AM
Yes, keep in mind that the front studs have a different diameter for the press fit portion. I went to the dealership and picked up a stock front and rear stud for measurement before ordering the studs.
svede1212
09-27-2009, 10:37 AM
-Will
i'm not sure why you think it's a bad idea to cut them to the proper length. it wasn't a problem. if you don't they'll be sticking out an inch past the nut.
svede1212
09-27-2009, 10:41 AM
you could have called ARP or just looked on the forums for the right part number. the fronts do have an unusual .565" knurl and the EVO is the only one that fits albeit the 3" length that needs cutting
TARZAN
09-27-2009, 11:18 AM
I don't like cutting them for two reasons...
1.) It CAN be done without screwing up the threads, but that doesn't happen often
2.) The reason they're required to pass tech is because they're longer.....cutting them defeats the purpose
-Will
