Generation IV External Engine - 650 Hp headers- What size pipe?
View Full Version : 650 Hp headers- What size pipe?
Ls2 cruiser
09-24-2009, 05:53 AM
What size engine pipes and twin exhaust would you need for a motor that puts out 650Hp N/A at the crankshaft? Cheers Russ
abbaskhan
09-25-2009, 11:16 AM
1 7/8 to to 3in
tals7
09-25-2009, 05:08 PM
i use 2in arh to 3.5 collectors to 4in over the axle mufflex with magnaflo muffler.made 658hp on superflo dyno.
Ls2 cruiser
09-27-2009, 04:32 AM
I am buying the Trickflow 225cc CNC ported 65cc comb. chamber heads. These heads flow 259cfm on the exhaust at .600 lift. I have found a graph on the net under David Vizards exhaust article and according to this graph it is something like 2 1/8" primary. Then because I am running 8 psi boost the pipes could even go bigger. My ls2 is still 364 cubes. Does anyone have any other thoughts on this? Cheers Russ
tals7
09-27-2009, 07:37 AM
for your combo 1 7/8 with 3in collecters sounds real good imo.
Ls2 cruiser
09-27-2009, 10:00 AM
Tals7, thank you for your help. What about with the FI - could I go to 2" primaries to let the flow out? Cheers Russ
Dustin601
09-28-2009, 07:33 PM
You could, but I think 1 7/8 will be plenty.
2000_SS
09-28-2009, 07:58 PM
Go 2" and be done with it. i've got 2" Kooks on my 454 and it's NA. a boosted 364 will move the same or more air than my 454, the more pipe you have, the better. i would AT LEAST go 1 7/8" stepped to 2" witha 3.5" collector, but that's just me. the car would still run fine with 1 7/8" x 3", but i'd go bigger.
Gordon0652
09-29-2009, 06:47 AM
My 440 will have KOOKS D-Port 2" to 3.5"
z28mccrory
09-29-2009, 08:23 AM
We used to run a 2000+hp outlaw car (400ci w/F3R blower) and ran 1 7/8 headers...
tals7
09-29-2009, 03:22 PM
you could use 2in headers but might lose a little down low with small cubes.when we dyno tested my motor we tryed stock ls7,1/34,1/78,2in headers mine just liked the 2in ones.i will tell you there was not a huge diff between them all.i made 653hp on the stock ls7 quads.
spooky_zo6
10-07-2009, 10:21 PM
Thers two ways to go 1 7/8 stepped 2.0inch or strait 2.0 inch in my past stepped headers make more tork....and tork is king..
Ls2 cruiser
10-15-2009, 05:20 AM
Thanks fellas for all the info. It gives me something to ponder over. cheers Russ
Jeff Smith
10-15-2009, 05:49 AM
I using Kooks D-shaped 1-7/8"-3" in my Ls2..Nice sound
KRAZY K 2000 TA
10-16-2009, 09:15 AM
1 7/8 to 3 is sufficient. i am going 1 7/8 to 2 stepped to 3 1/2 then to 4 inch y to four inch mufflex system.
