Generation IV External Engine - L92 Carb Style Intake
afattitude
09-25-2009, 06:32 PM
Does anyone know of any other intake than the Victor Jr. carb style EFI intake?
NemeSS
09-25-2009, 06:40 PM
gmpp l92 intake, or the yet to be released super vic for l92 ports
afattitude
09-26-2009, 08:23 PM
heard the gmpp only performs so so when getting up in600 hp ish. What is the best perorming manifod that hooks up with the l92 intake?
danhr
09-26-2009, 08:40 PM
probably the carry's when it comes out.
super victor is rumoured to come out some time soon as well.
but any step above the victor jr. at the moment would be a sheetmetal imho.
fknsmshn
09-26-2009, 08:42 PM
Whats your reason for not wanting the Vic Jr?
afattitude
09-27-2009, 11:34 AM
I called Edelbrock and they were saying that it is good to about 600 hp. I am looking at something that will work with boost and can handle 800-1000 rwhp. Any body out there pushing that much power and are using the Victor Jr.? I also didn't want to get a cowl hood. I wanted something that will fit under the stock hood and flows great
danhr
09-27-2009, 11:40 AM
the victor jr. is good well past 600 hp.
your best bet would probably be the new fast then, since you want to keep a stock hood and not cut anything.
you should start applying for new mortgage now.
danhr
3fingas
09-27-2009, 12:24 PM
Not here, a lil sluggish down low but with pwr adders its not too relevent.
highwaystar
09-27-2009, 12:37 PM
I just had an L92 head motor dynoed with a port matched Victor Jr that made 744@6800. It's a 14 to 1 race motor running a Pro Systems 4150 style carb. The Victor Jr is the most bang for the buck in an L92 aluminum single plane right now.
jleews6
09-27-2009, 01:44 PM
Dont forget that when they say 600HP thats N/A. I would have to think that the Victor JR would have no problem supporting 1200 plus HP with boost.
fknsmshn
09-27-2009, 02:07 PM
I see. As for the hood, are you against cutting the cowl to clear an elbow? As far as I know with an elbow and trimmed cowl you can run a stock hood.
1CAMWNDR
09-28-2009, 03:25 PM
You can also run a flat hood with a 4150 4 BBL throttle body and a carb hat.
Dustin601
09-28-2009, 07:29 PM
A low profile hat would be close with a stock flat hood, but I think it will work fine. I have about 2" from the top of my TB to the brace on the bottom of my hood.
http://i481.photobucket.com/albums/rr174/lambertvr4/DSCF0209.jpg
3fingas
09-28-2009, 09:10 PM
With an SS Hood with some notching.
http://img8.imageshack.us/img8/4172/air1dsd.jpg
http://img8.imageshack.us/img8/6253/air2b.jpg
1CAMWNDR
09-28-2009, 09:17 PM
Mine is an Accufab 4150 with no spacer and a Spectre hat. Just does fit under the hood. I did have to trim the bracing at the back though. Just so long as it does not have a hole on the hood surface :nod:.
Dustin601
09-28-2009, 09:29 PM
I agree 100%. If a carb style and a 4150tb is an option, jump on it, you will love it.
niceguyyy01
09-28-2009, 09:41 PM
What ecu are you guys using with the carb manifold and 4150 style tb? Can this be used with the ecu that is in the car or do you have to go to a BS3 or ?
Dustin601
09-28-2009, 10:48 PM
i'm running my stock 98 computer
niceguyyy01
09-28-2009, 11:32 PM
very interesting. I like the 4150tb idea much better. Do you have to change any wiring or fab anything special or do all the sensors bolt right up? Sorry for all the questions, but that setup looks sick.
1CAMWNDR
09-29-2009, 10:29 AM
The Accufab comes with a GM TPS sensor and a GM IAC sensor. It has 3 ports in the back of the base. The larger one in the middle is 1/8 NPT but I never figured out what the two smaller ones to each side are. I just epoxied them shut on mine.
flatchat
09-29-2009, 11:07 AM
What about cary's from perf-inductions?
Dustin601
09-29-2009, 11:29 AM
you can either extend the tps and iac, or cut the loom back and you will have more than enough wire.
my fast is the exact same way as the accufab. late model tps and iac, and the same 3 ports in the back. I went with the fast because they claim 75cfm more 1275 vs. 1200. i know they are probably the exact same, but fast is local and I wanted it right then. haha
1CAMWNDR
09-29-2009, 11:58 AM
His killer ass-stompin manifold will never fit under a flat hood. I doubt it would fit with a 4150 and carb hat under a stock WS6 or SS hood. You might get away with a 4" cowl hood though.
afattitude
10-05-2009, 02:14 PM
I have the WS6 Ram air hood. Do you think it would still require trimming? I also don't like the big ass cowl right in your field of view. My buddy had one and he got rid of it because you cant see anything on the road. Also for everyone to know, I do plan to put boost on the TA...alot of boost, prolly 15-20psi. So the TB will still need to be able to function with the procharger.
