Pontiac GTO 2004-2006 - What kinda power are you N/A Stroker guys making?
GTO JIMMY
09-27-2009, 03:51 AM
Im now officially tearing my goat down and going back N/A, just wondering what kinda power you guys are making.
My setup is gunna be the same 408ci with the pistons swapped out to some nitrous/NA ones, a set of AFR 225's, HEALTHY cam, Kooks 1 7/8ths with O/R mids through mufflers with a ported FAST on top. Just wondering if I will end up around 500rwhp N/A or if that goal is too high.
I would like end results of 500rwhp NA, 750rwhp on dope.
SIC GTO
09-27-2009, 08:46 PM
Id think you would be a little over 500rwhp, sounds like you're gonna have a badass setup!
pittman
09-27-2009, 08:48 PM
I agree.
I am running a 383 with afr 225's and mild street cam. Dyno was 480 rwhp..info in sig below. Going all out, I am seeing around 540 rwhp around the forums
Pitt
sergo
09-27-2009, 09:24 PM
cam selection will be the key. get a custom grind.
why the downgrade?
good luck on the re-re-re-build. lol!!! seriously though, how many times have you rebuilt that now?
GTO JIMMY
09-27-2009, 11:39 PM
why the downgrade?
A couple times LOL.
But I am just bored with it man, ready to switch things up. Im trying to gear the car more towards the track than street these days.
Tired of highway runs. :nod:
sergo
09-28-2009, 10:20 PM
good luck with it.
FMS_FTW
09-29-2009, 02:53 AM
Do you already have the AFR's? If not I would recommend some TFS 235's
GTO JIMMY
09-29-2009, 07:19 AM
What kinda gains does the TFS 235's make over the AFR 225's?
necrocannibal
09-29-2009, 08:50 AM
460 rwhp here with a 402 with a small cam and stock intake and stock air box. You can easily be over 500 rwhp if you go for it to a nasty set up, this is my DD so I went small.
gtslo88
09-29-2009, 12:11 PM
x2 also interested
FMS_FTW
09-29-2009, 12:58 PM
They make very similar peak numbers but the trickflows show a greater improvement in the midrange. I will try to find some comparisons when I have some free time.
quadman
09-29-2009, 05:06 PM
500 is a very modest goal. i did it with a very mild 236/240 cam/unported FAST. AFR/TFS.........you should do it with either.
LS12Fast4U
09-29-2009, 08:47 PM
quadman which RHS heads did you go with? How much and how do you like them?
Gregory
09-30-2009, 04:05 AM
Get heads that flow 330+ cfm and a good 240+ duration, .600" + lift camshaft.
I make 554 wheel HP and 492 wheel TQ with 93 octane on budget components and have room to grow.
6.0monsta
09-30-2009, 08:46 AM
504/491 through a built/stalled/geared auto gto with 416ci mild cam.
Car runs 10.9s.
Nimitz87
09-30-2009, 08:53 AM
Check out this thread...
http://www.ls1tech.com/forums/dynamometer-results-comparisons/816128-408-results-part-ii.html
Chad
danieloneil01
10-01-2009, 02:11 AM
408 seems to be a popular size. But how much more is it to go 454 or even over 500? I haven't heard of to many goats with a 454 (a few) but none higher. Are we talking 20k to go that big on just the engine if done like a stroker? Sorry extreme noob here.
Nimitz87
10-01-2009, 02:44 AM
yes much more expensive to get to the 454 cubes you need the LSX block which alone is 2k prior to machine work...500? contact ERL for the billet block which IIRC is 5k
you can do 440ci ls7's....
then you need to spend BIG money on a top end for a motor that big....there aren't to many if ANY heads that can feed a 440+ ci LSX motor to their limits....yet.
Chad
quadman
10-01-2009, 12:27 PM
i have the RHS 225 heads. i don't know if you can buy them new anymore.
i got them from a forum member in FL. he told me they only had 500 miles on them. i paid 2k for them, which, at the time, seemed like a good deal compared to 2400+ for AFRs, ETPs, or Trickflows new. so far i'm happy with them. some o' you guys putting down some BIG power na.........wow.
Jegten in New Mexico is building a 416 for his '04 GTO. Hopefully he'll get it in and fired up in the next few weeks. I'm looking for him to put down some sick power. He's going with a cam spec'd by Patrick G, i think.
slowgoat
10-07-2009, 12:09 AM
Cam profile is going to be the deciding factor IMO. Depends wether your looking to get the most out of the car N/A or on the jug.
For instance I have a 416 build for nitrous and it only made 487 N/A though a 4k stall A4 but when we hit it with the 250 Fogger shot it made 756hp & 888tq.
Probably could have gotten alot more out of it N/A but would have sacrificed alot of power on the bottle.
6.0monsta
10-07-2009, 04:49 PM
What's the specs on your build? Any track times/mph on motor?
jmdgto
10-07-2009, 05:17 PM
i have that exact same build and i made 507/470.
6.0monsta
10-08-2009, 12:34 PM
Exact same build as what?
