Dyno & Bench Racing Forum - Think my POS cobra will run 10.50's
Bitemark46
09-28-2009, 04:43 PM
Bored at work. :zzz: Will be putting on a intercooled novi 2k on in a few months. Just wondering what some of you think it'll do. I was hoping it'd go 10.50's in good air. But I'd settle for 10's with the stock longblock and the blower. Here's some info on my car:
3050lbs w/ me and fuel (pre-blower)
Current power: 320rwhp
Ok, time to walk around the office and get a coke. :burn:
-Mark
unit213
09-28-2009, 04:46 PM
Need some more info...
- built engine?
- how much boost?
- pump or race gas?
madmike9396
09-28-2009, 04:48 PM
hell yeah put in R for race and hold it to the rev limiter and drop the clutch lol, Seriously idk but good luck
Bitemark46
- built engine?
- how much boost?
- pump or race gas?
Stock longblock with just the addition of the blower
Going to try and limit it to 10psi. My hypereutectics and powdered rods are going to be really mad if I go any higher. lol.
The tune will probably be on 93 but I will add 100 for a safety factor.
EDIT: I want to stay under 450rwhp so the motor can live for a little. I'll build it later.
ponygt65
09-28-2009, 05:48 PM
Given how hard you run your car Mark, I wouldn't go higher tha 8psi for certain and I'd have it tuned around 400RWHP.
Personally, I don't think you'll drop over a full second with just the addition of 80-100rwhp. I may be way off on that and I hope I am as I'd love to hear of you doing so. I'd guess 10.9-11.1 area. A lot depends on how much you push it with the Novi though.
That's my 2 cents anyway.
chet3310
09-28-2009, 05:54 PM
Low 11s IMO
Bitemark46
09-28-2009, 06:13 PM
Its got a 3.5" pulley on it and that pulley has been known to make 14psi at 7k so with the IC and my free flowing intake and exhaust I don't think I'll make that much boost. My motor is about as efficient as I can get it in stock form. So what ever rpm it hits 10psi I'll set the limiter for that I guess.
It goes 1.56-1.59 60fts now I'm sure with another 100rwhp it should go mid to low 1.4's. That should put me in the 7.0's in the 8th at close to 100mph. That should be a 10sec pass I would think.
I've see full blown race cars weight just under 3k with 380rwhp run 10.80's. I figured I'm close to their weight and will have a hair more power that it should be close.
-Mark
Sarge_13
09-28-2009, 06:21 PM
-Mark
It will be really close. Depending on how you 60' I can see a 10.6-10.9.
ponygt65
09-28-2009, 06:47 PM
-Mark
you may not hit high psi, but that's only half the issue. WIth your airflow mods, it basically means you need less PSI for the same amount of power with someone that doesn't have those mods (generally speaking, not always of course). I just personally wouldn't go above 400-420rwhp 380-400rwtq on that short block. setting your limiter lower will help a tad, but with those cams and a centrif. charger you'll also lose some power up top by comparison.
I'd love to see you hit mid 10s no matter what power you're putting down though. :hail::nod:
unit213
09-28-2009, 07:56 PM
10.50's? Highly doubt it...even at your lean race weight.
10.90's? Very possible.
11.20's? More realistic.
Bitemark46
09-29-2009, 08:16 AM
Ya I think the 10.50's was a stretch. I'm sure it'll do that once I build the bottom end. But I'm I think 10.80's isn't too far of a stretch. Had a buddy with a 99 cobra that ran 11.80's n/a then hit it with a 150 shot it went 10.89 at 125mph.
-Mark
Heater
09-29-2009, 08:27 AM
Hope you have a spare block laying around...them rods are gonna be leaving the one in the car now :buttkick:
unit213
09-29-2009, 08:56 AM
They should be fine at the 450rwhp level. His ET is going to come from
raceweight and 60'...not power.
-Mark
I think you definitely could run a 10.90, but it'll most likely take some work to get to that point. I would expect some 11.30's the first time
out then you'll probably have to dial things in a bit to get it to run a number.
PowershifterNC
09-29-2009, 12:25 PM
always wondered how that Cobra ran 11.7x....that thing is a regular lightweight...I think you'll see high 10s with some practice. People forget you're adding torque too with the blower not just hp
Stopsign32v
09-29-2009, 02:59 PM
As much as I hate to say it no. Low 11's.
