Generation IV External Engine - need HELP!! Looking for pin identification on crank sensor
backdraft TD
09-28-2009, 08:01 PM
I'm trying to hook up my msd 6012 and it wont plug into the sensor. Called msd but they told me the correct plugs are on the harness:mad:, which if they wereI wouldn't have called.
Where can I find the sensor/volt/grnd info for the three pins on the crankshaft sensor? got the cam figured out.
I'm sooo close to firing this thing up
thanx.
chris.
Dustin601
09-28-2009, 08:19 PM
A=ckp sensor signal-input
b=reference low
c=ignition feed
backdraft TD
09-28-2009, 08:29 PM
Thank you Dustin, but I don't have the abc like the cam. Just the part number.
backdraft TD
09-28-2009, 08:33 PM
in other words...the sensor pins aren't labeled inside the plug like the cam sensor is.
Dustin601
09-28-2009, 08:40 PM
if memory serves correctly A is closest to oilpan and C is toward head.
from MSD to crank sensor
org/yel - A (pin on bottom)
brn - B (middle pin)
org - C (top)
Dustin601
09-28-2009, 08:43 PM
either way it is labeled the same way the cam sensor is, as far as the location of A,B and C. So you can just use those as a reference.
backdraft TD
09-28-2009, 08:54 PM
Thank you SO much !
Dustin601
09-28-2009, 08:58 PM
No problem.
