Pontiac Firebird 1967-2002 - Headlight stop broken
View Full Version : Headlight stop broken
N20zuki
09-28-2009, 09:38 PM
The white tab on my headlight stop is bent back and doesnt come in contact with the mechinisum. Should I be able to bend it back and be ok or is there a reason why it over extened? Car looks funny winking at you a little bit
great421
10-05-2009, 07:58 PM
Mine broke when I was removing the motor (to fix the worm gear) - when I got it back together, it would go up then right back down. I fab'd a piece of Aluminum L bracket from Lowe's Depot and made a new stop - no problem.
Ethan[ws6]
10-08-2009, 07:57 AM
If it's the stop I'm thinking (the one that stops the head light from closing too much) then I just used a bolt/nut and adjusted it as needed.
N20zuki
10-09-2009, 12:27 PM
I havent had a chance to tackle it yet, but yes its closing to much so that it is lifting the headlight up about 1/4-1/2in from being down.
Danny2tek
10-09-2009, 10:36 PM
read my sticky in there I mention how to fix that issue
Pitbull329
10-13-2009, 02:22 PM
If its the one keeping it from closing too much. I bought a little set of, I believe they were called, license plate tabs from autozone. They are in the section where they keep all the little bolts,nuts,screws etc. Came home and adjusted a new one properly, worked great.
