Pontiac GTO 2004-2006 - 2004-2006 GTO: Moser/EPP M9 Rear End Complete Installed Price
Exotic Performance Plus
10-01-2009, 08:49 PM
http://www.exoticperformanceplus.com/services.php?service=96
Check it out at the above link. Bob
GTO JIMMY
10-01-2009, 10:14 PM
$8500.00 Completely Installed.
10-02-2009, 06:15 AM
If you had that price for the V, I'd have done it in a heartbeat.
You do get a lot for the price. Bob
rcsfastmonte
10-04-2009, 12:58 AM
does this allow for bigger rear tires.
thebassbass
10-04-2009, 11:32 PM
i fit 325's under my custom sra with just a hammer. i don't see why you could not do the same with this, but if you do a minitub you could go with just about any size you want.
10-07-2009, 05:58 AM
http://i226.photobucket.com/albums/dd185/EPP_photo/GTOM9pic2.jpg
The suspension mounts are moved inboard so you can indeed run wider tires. Thanks. Bob
11-11-2009, 06:06 AM
Our new Moser/EPP GTO M9 rear is advertised in the new issue of GM High-Tech Performance Magazine. Bob
11-12-2009, 09:35 AM
http://i226.photobucket.com/albums/dd185/EPP_photo/EPPAd.jpg
This is page 96 from the Feb 2010 issue of GM High-Tech Performance magazine. Bob
s/c'd cav
11-12-2009, 07:43 PM
dam that is sweet !!!!!!!!
do you have any finished pics of the inside ?
any special deals if you mini tub at the same time ? since i know others will want to know
11-14-2009, 07:43 PM
http://i226.photobucket.com/albums/dd185/EPP_photo/Cody9.jpg
The interior doesn't look much different than what it did in this picture. Cody is planning on getting the rear seat downsized to fit within the confines of the wheel tubs.
http://www.exoticperformanceplus.com/services.php?service=96 $8500.00
http://www.exoticperformanceplus.com/services.php?service=95 $1780.00
We could do both together for 10k. Thanks. Bob
s/c'd cav
11-15-2009, 12:01 AM
looks good inside , does the area for the tq arm interfere with the rear seat at all ?
wish you guys were alot closer to me , lol
LS2tiger
11-16-2009, 09:37 AM
Questions:
What brakes are used on this?
What about the ABS?
What center section does it come with and what are the options?
Will standard catbacks work with this or will it have to have a custom one built?
s/c'd cav
11-17-2009, 04:45 PM
Questions:
What about the ABS?
i believe wilwood brakes - dont see it listed but coulda sworn at 1 time brakes were part of it
abs is not functional
your choice - see the rear end listed on EPP's site - http://www.exoticperformanceplus.com/performance_parts/index.html?item=1835
gonna need a custom 1 to clear the tq arm
11-17-2009, 06:29 PM
Thanks, no it doesn't. Bob
11-17-2009, 06:34 PM
Questions:
What about the ABS?
We did indeed use Wilwood brakes, I'll have to add them as an option.
ABS is not an option.
I have all the options for the center section listed.
A custom exhaust system will have to be created, such as what we did in the picture here. You could also easily add tailpipes to it to route the exhaust to the bumper. Thanks! Bob
http://i226.photobucket.com/albums/dd185/EPP_photo/GTO10-1.jpg
11-17-2009, 06:49 PM
Update: I just went in and added the Wilwood brakes as an option. Thanks. Bob
