Generation IV External Engine - 6.0 build need some help
Pate_2008
10-01-2009, 11:57 PM
i am getting the l92 heads and ms4 cam package from texas speed, i am looking for a intake that will work, was wanting a l76 intake and a 90 mm throttle body but hard to find or the victor jr intake with a 90elbow and 90mm throttle body. Question being will the l76 be a direct bolt on if i get that, and if i go the other way what all with i need with fuel rails what elbow will it fit under a stock ws6 hood thanks guys !
MelScrilla
10-02-2009, 01:26 AM
the L76 is a direct fit and shouldn't be that hard to find did you ask TSP they probably have one, but if they dont GM has them for sure; a LS3 or L76 intake will work.
The vic jr is cool to and yes you will need aftermarket rails and fuel lines to I believe and with a low profile elbow and a 90mm tb it will fit under the hood, but you really have to worry about the cowl more, they do have elbows that clear the cowl.
I've only heard not so great stuff about the elbows on vic's though especially when you run it n/a, on a FI car the pressure from the blower overcomes most bends in a intake system that kills flow in a N/A setup.
Also the new fast 102 is out for the L92 heads.
69LT1Bird
10-02-2009, 06:50 AM
e bay has a bunch of LS3 intakes from people putting superchargers on. Not too tough to find.
Pate_2008
10-02-2009, 12:14 PM
ok so a ls3 intake with the stock fuel rails that come on it and throttle body are a direct bold on the the heads and block i take it correct if so that makes things alot easier. thanks guys
69LT1Bird
10-02-2009, 12:16 PM
Yes, that is correct.
The L76 intakes was out first, that is why is shows up more often in the forums.
Pate_2008
10-02-2009, 12:19 PM
ok awesome and any 90 mm will bolt up to the L76 or the ls3 correct ?
69LT1Bird
10-02-2009, 12:21 PM
yes they will.
Pate_2008
10-02-2009, 12:22 PM
ok awesome thanks for the help !
NemeSS
10-02-2009, 12:47 PM
im not so sure the ms4 is optimal for the l92 heads and ls3 intake.
please post results of these heads and cam, also what is the scr?
Pate_2008
10-02-2009, 01:23 PM
well the ms4 and l92 heads come in a head cam package from texas speed, and the scr i'm not sure yet.
