Dyno & Bench Racing Forum - will this get me in the 11s
View Full Version : will this get me in the 11s
2fasst83
10-02-2009, 03:05 PM
i just want to see what yall think.
tsp 228r
edelbrock stepped lt
3 inch tds
ptc of texas 4000 stall
3.73 rear gears
ramdom tech tq
bmr poly lca
relocation bracket on last hole, ce rear shock set at 50/50
stock springs
bfg drag radial on weld, skinnies on front
slp lid,p&p tb ls6 intake
some weight reduction(no front sway bar, front bumper support, jack& spare, no padding under carpet).
so will it get me in the 11s
stumprrp
10-02-2009, 03:54 PM
easy 11's
zracer323
10-02-2009, 04:20 PM
Should have no problem with that setup. I say 11.6
BETTER THAN YOU
10-02-2009, 11:46 PM
i dont know. might be close.
JL ws-6
10-03-2009, 10:14 AM
I wouldn't put the lcs'a that low unless teh car is lowered, you want the arms pointing up (towards the front) about 2 degrees at ride height.
Thread is also being moved, this is bench racing at it's finest!
BETTER THAN YOU
10-03-2009, 12:16 PM
i think it might be close.
navyblueSS
10-04-2009, 09:19 AM
Easy 11's. I say 11.60 -11.70.
unit213
10-04-2009, 09:44 AM
Agreed. 11's should be a piece of cake with that setup.
2fasst83
10-05-2009, 10:25 AM
what would you set the torque arm at?
BETTER THAN YOU
10-06-2009, 04:10 PM
ttt...........
2fasst83
10-20-2009, 12:33 AM
well guys took it out to the 1/8th mile and it ran a 7.48 ,1.63 60ft, 90.58 mph. not bad. car still feel like it has more in it. oh and i also noticed that i am spinning the tires on the rims. ktime for rim screws. no bad for a dd cam only street car.
2fasst83
10-20-2009, 12:36 AM
going to the 1/4 in 2 week. we will see what it will do.
i will keep yall posted thanks everyone.
BETTER THAN YOU
10-22-2009, 08:30 AM
great job. car looked strong at the track.
ScreaminRedZ
10-22-2009, 08:37 AM
Good numbers! Should be good for mid 11's based on the 1/8 numbers I'd say.
2fasst83
10-30-2009, 08:50 AM
going to ennis this sunday if weather is good. hopefully i can get some 11.50s out of it. maybe i can get som 1.59 60 fts out of it
2fasst83
10-30-2009, 08:52 AM
so does any one think putting the lca on the last hole would help. i also have the ta set at -2 degrees. what do yall think. thanks in advance.
