JimMueller
10-03-2009, 10:47 AM
Not getting much feedbck on another site. Other than tuning for maximum torque for the entire RPM range, what other type of behavior is preferable? Things such as (and I'm looking for other ideas also):
- How fast/slow do you want the RPM's to fall between shifts?
- How fast/slow do you want the RPM's to fall when coasting?
- Do we want to be in power enrichment (i.e. WOT AFR) everywhere on course, or allow it to drop into stoich under certain conditions? Which conditions?
- OK to run AFR for optimal torque in autox because the courses are so short?
- How instant do you want the throttle response to be?
- insert more ideas here
Thanks!
Jim
Thanks!
Jim
