Dyno & Bench Racing Forum - Guess my horsepower
View Full Version : Guess my horsepower
Whiteboy572ci
10-07-2009, 08:31 PM
I am planning on getting a nitrous kit for my c5z. I already have lg streets, orx, stock ti exhaust, qtp cutouts, tr55 plugs, ls2 wires, cca catch can, Tex 0Z700-Z, comp 224/228 xer on 114+4, patriot golds, hardened pushrods and vararam intake. Im having it retuned and hope to see over 410whp na.
(still running the stock 10.5:1 cr, 243 heads and ls6 intake and t.b.)
Planned on using the nitrous express shark nozzle wet kit with the window switch (on-3000 off-6600) I have had good results on other cars ive used this setup on.
What should i expect this setup to make on a 50, 75 and 100 shot?
E.T.s given traction? :)
10secZ28
10-08-2009, 11:33 AM
I think you will make right around 500 on a 100 shot
CARFREAKS
10-08-2009, 12:41 PM
485-490 is my guess on 100 shot
Whiteboy572ci
10-08-2009, 09:48 PM
Sweet. Thats what i was thinking. Will the stock 32lbs be ok if i run a wet kit? I figure at some point a better fuel pump will be on the list.
black95z28
10-10-2009, 12:06 PM
Yes your injectors are fine because the wet kit mixes nitrous with fuel. Now if it was a dry kit then you would need larger injectors.
black95z28
10-10-2009, 12:08 PM
Also a better fuel pump is good insurance. That is unless you get a fuel pressure safety switch with the stock pump. This way even if it drops fuel pressure it wont kill your engine
daniel6718
10-10-2009, 10:40 PM
new plugs...
5_02ls1
10-11-2009, 01:06 AM
yeah id go 2 steps colder on the plugs with that setup....dithc the tr-55s....theres a plug list in the stickies...and dont let some idiot tell you that you will lose power.....colder plug= safety.....
should be a fun setup though....im gonna say 490ish on the 10 shot...lol
Whiteboy572ci
10-11-2009, 09:49 PM
Yeh, already have a set of TR6s i havent used.
