Dyno & Bench Racing Forum - 1/4 Estimate: Got all the info you need.
OMGWTFBODY
10-09-2009, 11:44 PM
1998 Trans Am
3.73 rear gear
8.33@85.7 1/8th on a 1.90 60'
8.42@85.5 1/8th on a 1.99 60'
M6
346 hp 347 ft/lbs, on a Dynocom loaded Dyno
3417 lbs without Driver.
I would guess a 12.8 or so...
unit213
10-10-2009, 06:43 AM
Those times convert to a 13.0 @ 106mph.
OMGWTFBODY
10-10-2009, 10:00 PM
I can do a conversion. I am looking for someone with similar times/speeds in the 8th and how they ran.
unit213
10-11-2009, 08:19 AM
Ok, then see my post above.
OMGWTFBODY
10-13-2009, 10:18 AM
=( I was hoping to run a bit stronger.
PowershifterNC
10-13-2009, 12:38 PM
that'll prolly be up to you...let us know what you run
unit213
10-13-2009, 07:31 PM
I sorted through a couple hundred old time slips looking for one that was
similar to the increments you posted.
http://i38.tinypic.com/245dcic.jpg
60 - 2.080
330 - 5.617
1/8th ET - 8.496
1/8th mph - 85.87
1000' ET - 10.983
1/4 ET - 13.095
1/4 mph - 106.84
That was done with my 2000 A4 LS1 that weighed 3,400lbs without me in it. So, as I stated previously, that converts to a 13.0 @ 106mph.
How's that for "something a little stronger?" :D
OMGWTFBODY
10-13-2009, 08:01 PM
That almost exactly matches my run.
It would put me at a 12.95 or so with my 60'
But it's also an M6, so I should pick up more downtrack.
It's irrelevant now, my 10 bolt died. =(
unit213
10-13-2009, 09:40 PM
Bench racing to the hundredths place is a pushing it a little too far. :lol:
There's too many variables...shifting ability, clutch slip, missed gears, etc.
The car is capable of 12.90's, but you'd realistically see a 13.0.
PowershifterNC
10-14-2009, 12:54 PM
hope you're going with a 9"...don't waste time on anything else
OMGWTFBODY
10-14-2009, 06:30 PM
10 bolt.
It was in my budget.
