Paint & Body Work - CME Fender Help!
tonys02slpss
10-10-2009, 06:32 PM
On my 2002 Camaro SS SLP#5878 the CME fender on one corner is separating from the bumper what can I buy to glue it back to the bumper?Thanks
LS1-MEX
10-10-2009, 06:39 PM
if u have it itstalled correctly there is no way it could seperate.....but use really thin double sided tape
tonys02slpss
10-10-2009, 06:44 PM
I didnt put it on it came stock with it.Do you think tape is going to hold it?I think they use some kind of glue I just dont know what kind.
tonys02slpss
10-11-2009, 12:21 AM
Anyone?
thewholefnshow1
10-11-2009, 12:47 AM
I would like to know this also
Jessfly1
10-11-2009, 09:14 AM
on the fender there shoud be some place where the bumper slides into a bracket or is fastened in some fashion. you dont want to use glue because there needs to be some flex between bumper and fender due to the differance in material. i guess you could use double sided tape but i wouldnt doubt it if it didnt last but a week or two. There should be some sort of physical connection i.e. bracked, nut-bolt ect.
tonys02slpss
10-11-2009, 11:08 AM
I checked and it use like brackets but it also has some kind of adhesive all around the bracket because I can see where it is separated.
Jessfly1
10-13-2009, 03:59 AM
Are you the original owner?
bmnicolosi
10-13-2009, 12:22 PM
vhb double stick tape. They use that stuff to hold aluminum panels on the side of skyscrappers, it will hold for you. Its the same stuff that holds most emblems and moldings on cars.
W8S SS
10-13-2009, 02:32 PM
My 6LE valance is the same way on the passenger corner. It's probably from the heat and humidity from Florida.
