Tools & Fabrication - LS Engine puller plate
the_merv
10-11-2009, 03:32 PM
Has anyone seen a plate that you can bolts to where the Valley Cover goes and use it to pull/lift the engine?
I was just wondering.. I'm about to put my engine back in soon and it would help..:)
highwaystar
10-11-2009, 05:34 PM
Yep, Car Shop and a few other sponsers have them
RARON455
10-12-2009, 11:56 PM
QTP makes one to.
the_merv
10-13-2009, 08:44 AM
I actually made one earlier today out of some steel I had laying around. I just need some Grade 8 Bolts and I'm good. :chug:
The holes aren't drilled yet, but you get the idea..:cool:
http://www.ls1tech.com/forums/attachment.php?attachmentid=201351&stc=1&d=1255405900
01ssreda4
10-14-2009, 04:52 PM
weld looks a little cold :jest: No, seriously, your weld looks a little cold :jest: You wouldnt need that plate if you took the motor out from the bottom :D
daniel6718
10-15-2009, 12:48 AM
bottom ftw...dont have to pull tranny or wire harness or headers or accessories
the_merv
10-15-2009, 02:04 AM
K..even if you pulled it from the bottom this little thing will help get it off the K-member with the Cherry Picker..think outside the box fellas..;)
A friend of mine welded it..it works. :)
NemeSS
10-15-2009, 03:18 PM
if u gonna pull out the bottom, might as well swap in a tubular kmember while your there.:jest:
i have always pulled it out the top with hood in place and with trans attached.
merv, i made one like the one u made, but i had the plates made on a cnc waterjet. with a dust shield also, but i dont think there is a market for them.
qtp and other alredy make similar designs
99Bluz28
10-15-2009, 04:33 PM
The QTP-10100 is about $53, 1/4" stainless steel.
Phoenix 5.7
10-16-2009, 01:56 PM
not the best, but i cut the knock sensor tubes off of a spar valley plate and used that for my last engine swap
the_merv
10-16-2009, 02:32 PM
^^I'm suprised that Cast Aluminum didn't break.
01ssreda4
10-20-2009, 08:59 PM
Me too, cast aluminum is weak shit :D
hookemdevils22
10-20-2009, 11:11 PM
like this? 1/4" plate steel. The base is 18.5" x 6", and the vertical plate is 12" x 2.5" with three 1.5" holes. I used the valley cover to mark the bolt holes and drilled them slightly oversized. Note that you have to remove the cam sensor unless you grind it down in the back. $14 for the steel plus weld time, or free if you have some scrap metal chillin' at the shop.
http://i105.photobucket.com/albums/m235/hookemdevils22/Nova%20Pics/LQx/Current%20Build/nova003.jpg
Big_Bird_WS6
10-22-2009, 04:41 PM
i got two laying around. 55 shipped. made out a stainless.
Big_Bird_WS6
10-22-2009, 04:44 PM
for pulling them out the top. i made one with a leveler bar on it. all out of a water jet. and 1/4" stainless. works great.
tittan1500
10-22-2009, 05:13 PM
I used the TPIS happy hooker. It worked good and the motor slid right into my trans am.
it has a bend it the lifting hook that helps get past the cowil on the 4th gen cars.
http://www.tpis.com/index.php?module=catalog_page&catalogPageNumber=110&catalogSubCategory=Happy+Hooker
serpentnoir
10-23-2009, 12:30 AM
I worked once. doesn't mean it won't break the next time.
You couldn't pay me enough to stand under it. Those welds are horrible. Find someone else to do your welding...
rtpassini
10-23-2009, 07:00 PM
is that the only way to take out the engine with a cherry picker?
seems like a lot of work to get that bolted on (but i have never done it so what do i know. haha)
73 nova guy
11-14-2009, 04:11 PM
here are the two i built..
http://i65.photobucket.com/albums/h232/rackerman62583/P1050647.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050649.jpg
one out of 1/4 aluminum
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/P1050421.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/P1050422.jpg
Not pretty, but it works.
http://img21.imageshack.us/img21/1452/20091114engineliftplate.jpg (http://img21.imageshack.us/my.php?image=20091114engineliftplate.jpg)
LoudGM
11-14-2009, 07:18 PM
Ive seen them and they work ok, but from the botton FTW for sure!!!!!
BLOWNBLUEZ06
11-18-2009, 04:39 PM
Here's my rig job. Nice, cold welds too. :cheers:
http://www.bradbury.org/bret/enginehoist.jpg
http://www.bradbury.org/bret/engineinstall2.jpg
