sinful7
10-11-2009, 09:54 PM
I think there is a lil work still to be had on my tune.. but here are all the numbers..
mods
ls1 stock short block (fresh with only 2000miles on it) with arp rod and main bolts
patriot stage 3 5.3L heads
vodoo 228 duration .567" lift cam
1.75 ratio roller rockers
hardened pushrods and ls7 lifters
kooks LT headers 1 3/4" tubes
2.5" to single 3" exhaust flowmaster 40 muffler and no cats
ls1 intake and stock tb (yes i know it kills but its still what i got)
stage 2+ spec clutch
MSD plug wires and bosch +4 platinum plugs
12 bolt rear end with 4.10 gears and a locker
SLP LID and descreened MAF
this is with a t56 6 speed car of course, with 275/40zr17 tires on the rear.
future mods will be in near future:
LS6 intake and ported TB
125hp nitrous wet kit
dyno numbers are below.. if i can scan the sheet i will, on a mustang dyno so numbers are at rear wheels on a 4th gear pull.
max power 397.7hp at 5100 rpm
max torque 430.76ft/lbs at 4600rpm
rpm- hp/A-F/torque
2500- 41.75/14.54/87.01
2600- 145.8/14.53/294.46
2700- 194.8/14.09/378.94
2800- 211.3/13.43/396.47
2900- 221.3/12.94/401.23
3000- 231.9/12.82/405.98
3100- 240.8/12.88/407.87
3200- 247.7/12.95/406.55
3300- 255.5/12.98/406.60
3400- 266.7/13.0/411.92
3500- 279.5/13.01/419.41
3600- 289.9/13.0/422.83
3700- 296.2/12.98/420.37
3800- 299.8/12.97/414.32
3900- 304.8/12.97/410.51
4000- 314.4/12.96/412.71
4100- 325.2/12.95/416.46
4200- 333.3/12.95/416.80
4300- 340.8/12.96/416.27
4400- 350.7/12.95/418.60
4500- 364.4/12.91/425.38
4600- 377.3/12.87/430.76
4700- 384.8/12.86/429.91
4800- 385.7/12.9/421.97
4900- 387.9/12.94/415.80
5000- 394.2/12.99/414.02
5100- 397.7/13.01/409.39
5200- 389.5/13.02/393.73
5300- 379.2/13.01/375.73
5400- 377.9/13.03/367.57
5500- 385.7/13.07/368.36
5600- 368.6/13.13/345.68
5700- 219.0/13.38/201.73
thats where we stopped it for now. the timing ended up being 4 degrees retarded also. the cam builds power to 6700rpm or supposed too but we were falling off quickly so we figured the ls1 intake was killing us so we quit till we get a good intake..
any thoughts?? or even guesses what will happen once we get the ported tb and ls6 intake on it??
mods
rpm- hp/A-F/torque
