11 Second Club - what tires are you using
formula4437
10-12-2009, 11:41 AM
my car should be in the 11 if i could get traction. ran a 12.3 on my 315 street tires spinning like crazy. wanted to know what most of you are having good luck with. i am looking at the mt drag radials 255/50/16 or the equivelent size of mt et streets. i have 415 rwhp and my mods are in my sig. thanks
Gaunt
10-12-2009, 11:56 AM
3600 stall 255/50/R16 MT Drag Radials
Eibach drag springs, kyb adjustables
1.63 60 ft.
jsafe
10-16-2009, 10:04 PM
nitto 555r here
69LT1Bird
10-16-2009, 10:20 PM
275/60r15 MT drag radials
speedshifterNC
10-17-2009, 11:37 AM
right now MT ET Streets but buying MT ET Drags
FiFdYnUtz
10-19-2009, 11:05 PM
i was running bfg drag radials with completely stock suspension (sway bar removed only) on stock wheels and cut a 1.7 dead hooking...im moving on to MT dr's next though
Bill'sWS6
10-20-2009, 12:09 PM
I have tried both Nittos and MT ET Streets and give two thumbs up for the MT ET Steets. The MT just hook better, no doubt about it.
Magnet
10-20-2009, 01:59 PM
Nittos are a street drag radial, Mt's are a strip drag radial. Match your tire to your combo. If you have the drivetrain to support it then run the stickiest tire you can without bogging your motor. The normal option is a MT radial, assuming you have a built rearend or an auto. Stay away from it if you have a stick and 10 bolt.:nod:
FiFdYnUtz
10-20-2009, 02:15 PM
i will say i found my bfg's to be a happy medium between the nittos and mt's...
MikeG
10-21-2009, 01:46 PM
I have found Hoosier drag radials to be the best if you are looking for STRICTLY strip performance. They are the lightest DR available and hook better than any other I have used. They also wear the fastest though. They are not for street use supposedly but as long as the weather is ok I have no issues with my 30 mile round trip to and from the track. Best 60' so far is a 1.556 with my bolt-on car.
TORCHD 02 TA
10-21-2009, 09:54 PM
:lol: this is crazy... On my TTMs, i had 315/35 Nittos STREET TIRES and my best time was an 12.3 @ 115. and I too make about the same HP as you i am at 420..
But this year i put on my 16s, got me some M/T ET Street DRs 255/50/16 and ran an 11.8 @ 119 jsut from a tire swap :D
Moral of the story.. get the tires
blu byu EH
10-22-2009, 03:52 AM
I have MT 295/50/16 (11.5" wide 28" tall), I have adjustable lower control arms, on the car adjustable pan hard bar and the front sway bar removed and I did a 1.59 60' in a six speed car.
02 wife
10-22-2009, 07:08 PM
I hit 11's on nitto 555r several times!
