chevellepowered
10-12-2009, 04:01 PM
ok ,well i change my mind agian..
selling my setup in my 70 chevelle..
i was in the middle of converting it to blowthru carb, but i going for a n/a setup now..
parts.. has a 5.3 with arp head bolts ,rebuilt 853 heads, with 3 angle valve job, compcams valve springs duel,.650 lift,, has ls6 cam, truck intake and rails,comes as a long block with water pump,no alternator, no starter,and u can have coils.no oil pan/. if u want them trans is a 4l80e,its in my car too. 100% runs.. i was going to put a manual valve body in it. ,stock stall .
turbo is a mpt-70 master power i bought it brand new and put 2,000 miles on it, less than 1,000 miles with it tuned and ran it at 14 psi ..ran flawesly.. i have a turbonetics 44 mm wastegate ,i bought it used,,ran great,,
i have the pcm if u want to go with efi,already tuned for this motor and 60lbs injectors. u would need harness to complete this and fuel pump,injectors,, i have more than 3500 in this,,, i will sell for $2200 final offer,, if no one buys it i will finish it with carb setup and sell it with blow thru carb setup, for alot more than $2200.. i am not selling carb conversion parts..
