Generation IV External Engine - converting LY6 to DBC
View Full Version : converting LY6 to DBC
bfrank79
10-14-2009, 08:48 AM
I got a LY6, im keeping the stock intake and want to ge rid of the DBW. what TB should i use and where can i get the linkage and cable to make it work?
pillagenburn
10-16-2009, 12:55 PM
are you using this in a f-body and are you using the stock e38 ecu?
edit: have you also pulled out the VVT etc?
John@Scoggin
10-16-2009, 02:07 PM
92MM TB (http://www.sdparts.com/product/SD92MM/BilletThrottleBody92mmLSXCableOperated.aspx)
Cable Bracket - 44.95
on hand ready to go!
pillagenburn
10-16-2009, 03:19 PM
wow... expensive... might as well pay to have it wired up and $50 for a drive by wire gas pedal.
edit: assuming youre still using the e38 ecu...
