Dynamometer Results & Comparisons - Disappointing 408 Results
View Full Version : Disappointing 408 Results
LS1ROPER
10-14-2009, 02:54 PM
Here's the details
TSP 408 shortblock
Stage 3 tsp LS6 plus hand worked locally milled 59.5
YT rockers 11.64scr 8.54 dcr
Fast 92/92
24x/24x 62x/6xx 112+2
EWP
6speed thru TEX clutch
4.11 9"
Numbers 467hp 445tq
cutout open 476hp
Dynoed on dynojet by Geoff at EPS Great Guy lot of good info!
Thinking about going to TFS235's what are your thought on swicthing heads and dyno results?? Sorry dont have the graph Geoff didnt have printer on dyno computer!
GRAPH ON POST #22 THANKS MACH1
blu1
10-14-2009, 03:43 PM
You will definitely pick up a lot with the TFS 235's, the question is how much? Won't know until you do it ;)
I will say I think its worth it and their are a few recent 408's with similar mods as yours making 540-550rwhp but those are Vettes with 4.10's. I think 530 is within reason with your setup depending on how well the cam matches up to the heads. Also make sure the valvetrain is set up properly.
Can you post the graph? Its definitely very low for a 408 with those parts. What is the exhaust setup?
blk00ss
10-14-2009, 04:22 PM
What headers, y-pipe, size, where is the cutout at?
LS1ROPER
10-14-2009, 04:31 PM
Kooks 1 7/8 flowmaster merge, cutoff under pass rear seat, magnaflow 3" exhaust
Billiumss
10-14-2009, 04:41 PM
Unless the head porter has a lot of experience in LS style heads and have proven results time and time again, I'd say the heads are to blame for your low numbers. All your other mods look good.
With a good ported 243 head, you should hit 500 RWHP with no problem.
LS1ROPER
10-14-2009, 04:49 PM
Flow numbers on the heads were 315int 215exh at .600
mach1
10-14-2009, 04:53 PM
afr during pulls? what do your timing tables look like? what did the local porter do to the heads?
smok'nZ
10-14-2009, 04:56 PM
should be alot higer maybe if those were stock 3243's but stage III from tsp how many miles are on the motor?
LS1ROPER
10-14-2009, 05:07 PM
cleaned the combustion chambers! Dont think stock heads would be better than stage 3 heads 2.08 1.60 valves opening to 4.00 bore etc...
LS1ROPER
10-14-2009, 05:12 PM
Waiting on Geoff to email me the dyno sheet!!
Ryne @ CMS
10-14-2009, 05:15 PM
peak flow numbers arent everything.... what does the whole flow curve look like
smok'nZ
10-14-2009, 05:17 PM
thats not what i was saying i meant your numbers look like your car had stock heads not CNC'd heads with a 2.08 valve
LS1ROPER
10-14-2009, 05:20 PM
lft int exh
200 140 112
300 204 177
400 258 199
500 296 209
550 310 213
LS1ROPER
10-14-2009, 05:22 PM
Sorry mistook what you meant
mach1
10-14-2009, 05:25 PM
do you have any dead animals stuck in the intake?
looking fwd to seeing the dyno graph
02SLOMARO
10-14-2009, 06:11 PM
/\ /\ /\ :D for real. i would think that thing would easily put down 520 ish.
LS1ROPER
10-14-2009, 07:33 PM
Geoff sent the sheets but I cant open them, anyone want try, send me your email thanks!
mach1
10-14-2009, 07:42 PM
sales at supraspeed.com
LSRacing
10-14-2009, 07:43 PM
I went from the TSP stage 1 heads to the TFS 225's and would never look back. This is on a 6.0L. I think it would be a great change for your car. I love the animal stuck in the intake theory, lol
sum guy
10-14-2009, 09:33 PM
If it were my motor and I was sure the tune- afr, timing ect. was right I would look really hard at mechanical, leak down test, cam timing (with a degree wheel not just dot to dot)
XtraCajunSS
10-14-2009, 09:54 PM
I know Geoff's dyno is conservative but those numbers sound really low for your combo. I'm sure Geoff would have picked out anything obvious in the dyno graph for you such as valve float, clutch slippage, etc... The TFS/TEA 235's might be a little overkill for your app. I'd look at the 225's to boost torque with a cam of that size and 4.10 gears...
Shane
mach1
10-14-2009, 11:15 PM
Here is the graph
cam75w/ls1
10-14-2009, 11:40 PM
I'm not a tuner by any means but have studied alot of A/F graphs on other peoples dyno sheets and you look a little rich. Could run leaner safely and get more power that way I guess. Where's your timing at?
lilbuddy1587
10-14-2009, 11:55 PM
Mis-matched combo IMO.
venom ws7
10-15-2009, 12:07 AM
Really low numbers...
We've made 515rwhp with TSP PRC LS6 Stg 2.5 heads, PatG Cam, fast 92/92 intake and tb, TSP 1.7/8 Headers true duals, M6 Car 3.42 10bolt and only 11:1 compression with hot wheather too.
I know your 9' is taking some power but not that much.
rpmauto
10-15-2009, 12:14 AM
my vote is the heads,for some reason the ported factory castings dont always make good power,my 402 is a perfect example. I have seen as many poor #s as good#s. Thats why my "Mamofied" 225s are on a ups truck someplace now.
LSXDoc
10-15-2009, 12:39 AM
look at timing and massage the air to fuel ratio a little, cheaper option first before dropping more money on different heads, unless $$$ isn't an issue
smok'nZ
10-15-2009, 12:47 AM
i dont think the tfs would be over kill but he should be making more power than it is now those would be nice numbers for a 4l60 or th400 unlocked
Billiumss
10-15-2009, 08:00 AM
Exactly! :nod:
LS1ROPER
10-15-2009, 08:30 AM
The cam was spec'd by Patrick G. All of the bolt on parts were researched and tought about for a long time. Going into it I knew the LS6 heads would be my weak link just didn't think they would be that big of a bottleneck!
rpmauto
10-15-2009, 08:50 AM
^^^that is exactly what i thought, i made 470 rwhp-m6 and a 12 bolt. I was on a budget when i was doing the motor, as i was also completely redoing the body. I wish i would have just waited and got the good heads from the get go. What gets me is there are some people that make great (peak) #s with the budget heads. I was hoping to be one of those people. I just ran mine the way it is for part of last summer and this summer (probably less than 2k miles) and saved up for a good upper end.
Abdullah
10-15-2009, 09:29 AM
Here's the details
TSP 408 shortblock
Fast 92/92
EWP
4.11 9"
Numbers 467hp 445tq
cutout open 476hp
go with TFS heads from advanced induction (AI), they have great heads. tell them all info about your 408.
Frost
10-15-2009, 11:19 AM
I love these posts... you are making the assumption that his tuner is not thorough or doesn't know what he is doing. You would be wrong. You would also be wrong if you thought that there was more than another 2-3 to get out of it from the point that Geoff left it at. People on here think there is some voodoo to tuning.... there may be for driveability, but not for WOT. They make what they make. Of course that never stops anyone from posting stuff like "check your toon" rather than having folks look to the real problem areas.
LS1ROPER
10-15-2009, 11:29 AM
I am satisfied with the tune Geoff gave me car actually made 476 with the cutout closed but Geoff said that was on the edge of detonation, knock and he was not comfortable leaving it there because of the possiblity of engine damage. AGAIN I AM NOT BLAMING GEOFF FOR THE POOR NUMBERS!!
Brian Tooley
10-15-2009, 11:57 AM
I saw where you picked up 64 RWHP and 50 RWTQ over your TSP heads and cam, what cam where you running with those heads?
FWIW, I had a guy with a 402 pull TFS 225's off and install TFS 235's and picked up over 10 RWHP and over 10 RWTQ, so I think the 235's are a consideration.
mach1
10-15-2009, 02:17 PM
Across the board? Did he lose any down low?
edcmat-l1
10-15-2009, 02:40 PM
SAY WHAT???!!!??? You mean your HPtuners or EFIlive didn't come with the +50HP button???????? You better call em up and get the new version. :D
XtraCajunSS
10-15-2009, 02:59 PM
Geoff only uses the +50 button on VERY special occasions!!! Its called "hold the bottle in front of the airlid..." :jest:
you can ask Jason99TA about the BMW nitrous fire...:secret2:
Shane
69LT1Bird
10-15-2009, 06:53 PM
It looks to be about 12.5:1 so maybe getting it to 13:1 will get it another 30hp.:poke:
XtraCajunSS
10-15-2009, 08:26 PM
Seriously, I talked with Geoff today about this car in particular. The car was on the edge of detonation and is tuned as far as possible as the car sits. I would say this car should dyno in the 480 range on most dynojets, Geoff's is the 224LC which in my experience reads 20-25 lower than the old 248 we had.
Shane
firefighter813x
10-15-2009, 08:44 PM
My friend has a LS2 402 with almost the same mods with the TSP stage 3 LS6's and made 47x. He lost power going from a MS3 to a bigger cam too. We also think that the heads need to be swapped. Trickflow advised the 235 i think, don't quote me on that. Those numbers are on at least 11.5 compression too.
DopeFedZ
10-15-2009, 09:38 PM
FWIW, same cubes, TEA LS6 heads, 24x/25x cam,Fast90(home ported),TPIS 90tb, Kooks 1 7/8 ory w/4"cutout, 4l60 3600 through a 12 bolt made 505/450ish. Stock fuel pump was going out as I only had like 50psi of fuel. Maybe the heads were "overworked"?
'Trust'
10-15-2009, 10:07 PM
If it is on the edge of detonation, what gas are you using? I would say it could take a little less fuel and lean it out, but I don't know the conditions or what the car was doing. The only argument I have with the graph is smoothing at 0, makes it hard to compare apples to apples, but it looks like a good graph so no beef there.
LS1ROPER
10-15-2009, 10:15 PM
Gas used was 93. Just ordered TFS235 from Ron at Vengence think that should take care of everything:nod:. Hopefully some of that Vengence magic gets put in the box when they ship the heads!!
slow trap
10-16-2009, 08:42 AM
you will have a beast now. some people have really low numbers with ported stock heads and some get lucky. my junk puts out 53x rwhp with a scrub
244*@ .050 cam through 1 3/4 tubes with a ported 243 head but alot of folks aren't as lucky. the tfs 235 head is an awesome head. you will be more than happy with them.
lilbuddy1587
10-16-2009, 11:22 AM
Your heads and cam is what I was referring to. I'm sure Pat did a great job but it seems that the TSP heads are all over the place... and I'm sure whoever did the "hand work" did make things much better...
LS6 heads in the right hands, such as Tooley's (Since he is a sponsor posting in this thread ;)) can produce results that would hang right with any other aftermarket head (within reason of course).
Best of luck with the TFS 235's. I'll bet you pick up quite a few ponies :thumb:
