Dynamometer Results & Comparisons - Bolt-On A4 Dyno numbers (seem high)
Trav's_TransAm
10-14-2009, 04:34 PM
So I recently dynoed my '99 Trans Am and it put down 350hp and 355tq untuned on a dyno dynamics. All I have done is QTP Headers bolted directly to dumped Moroso Spiralflows, Volant Cold Air Intake sealed to de-baffled WS6 Hood, LS6 Manifold, and Ported TB. I think these numbers are high for being untuned. What do you guys think? Ill try to post the graph later tonight. Any input would help. Thanks.
LSWon00
10-14-2009, 07:21 PM
I'm saying yes that these numbers are too high. But what you need to understand first is that a dyno program can produce any reading if the setting aren't entered accurately (Density altitude). For a comparison when my 02 Z28 with LTs, Cat-Back, Lid, and TB had 700 miles on it it made 332whp and 336wtq and the car is an A4 with a 3400 stall.
You're not alone though, a few years ago I went to a dyno day where a guy with a 00' FireHawk with cat-back, lid, and MAF dynoed 380whp. Now most anyone who knows LS motors knows this is not even close to being correct. The guy was in our car club and argued that the numbers were correct since he had a print out.
I for my purpose only use a dyno as a means of tuning and take the HP and TQ numbers very lighly. When you go to the track compare your results from before and after you changed setups, if you gained MPH then you gained HP and as we know racing isn't done on a dyno.
GreenBlood
10-20-2009, 04:04 PM
take it to the track and compare
stealthy_2005
10-20-2009, 05:23 PM
I put down 33x rwhp and 340 rwtq with the mods in my signature with somewhat of a tune. I think some motors will just run better, I know it sounds stupid... but if some cars are lemons, then some have to be lemonade!
ScreaminRedZ
10-21-2009, 05:57 PM
Numbers look high to me. Like they said, the real way to use them is to see and maximize gains from new mods and tuning and then test it out at the track. Obviuosly if you show a 50 rwhp gain on the dyno and then run the same mph then something's up.
MNR-0
10-21-2009, 07:54 PM
Dynojet?
TXZ28LS1
10-21-2009, 08:48 PM
with my 02 Z28 A4 with just a lid, ported tb, ls6 intake, pacesetter longtubes, ory,magnaflow catback and 2.73 i put down 322/333.
Kingc8r
10-22-2009, 06:09 PM
My car with 1 3/4 LTs, O/R Y, Cb , Electric Cutout, SLP lid, FTRA, LS6 Intake untuned made 332hp....
I would say your numbers are high....even tuned I don't think I would hit 350 hp
2001taws6
10-23-2009, 08:43 PM
I think its a little high. My car put down 344/360 with mods in sig.
SweetS10V8
10-23-2009, 10:43 PM
Dynojet?I call them Ego-Jets
LSX Truck
10-28-2009, 02:03 AM
sounds about right. what mode was the dyno in where you runned it? Shoot out mode increases power at the flip of a switch
SweetS10V8
10-28-2009, 05:05 AM
sounds about right. what mode was the dyno in where you runned it? Shoot out mode increases power at the flip of a switchNever heard of that one before? What dyno has that?
Trav's_TransAm
11-01-2009, 08:38 PM
It was on a Dyno Dynamics at a dyno day. Here are some other numbers for the day if that helps.
'03 LS3 Vette (stock) 405hp and 400tq
'07 Z06 (stock) 441hp and 430tq
Twin Turbo '03 Z06 688ho abd 670tq
When I was stock i was running 13.4s at about 103. After I did everything I ran 12.8s at around 109 bouncing off the rev limiter in second. Cause of my exhaust setup I have no low end but all top end. Hope this helps.
