Advanced Engineering Tech - ignition coil with or without amplifier
jeejee
10-14-2009, 05:48 PM
How can i find out if a coil has a build in driver / ignitor ?
This is not specifically Ls engine related..
The reason i ask is, i have a aftermarket ecu and this can only fire coils with internal driver, If i would use a coil without one, i would blow the ecu. :bang:
this is the coil in question , it has 3 connections..
http://www.ignitioncarparts.co.uk/%5CProductImages%5CPC7010.jpg
thanks, Jeejee
jeejee
10-18-2009, 01:41 PM
Well, where are all the tech "guru's" ?
jimmyblue
10-19-2009, 11:26 AM
A coil with no built-in electronics only needs IGN,
switch and plug. That's a 2-pin connector. But I
would want to go to the donor vehicle's shop manual
to make the call.
