CaMaRo67RS355
10-14-2009, 08:29 PM
Take offs from my 2002 SS M6 Camaro less than 49,000 miles for all some have even less. Everything was in perfect operating condition when removed. If you have additional ?’s about anything let me know. Pictures available at request. Everything is OBO so feel free to make an offer on anything, but please no obvious low offers. All prices are WITHOUT shipping. I am aware everything does not have a price I am doing my best to research what the going rate is for each item if it’s not there just make a reasonable offer.
Misc Aftermarket Parts:
-Royal Purple MAX ATF Fluid 6 quarts new never opened new 12 each new my price 9 each
-Granatelli Red Cold Air Tuned MAS with Ported Anodized Red ends less than 1,000 miles380 new my price 300
-NIB Energy Suspension torque arm busing black part #3004 fits 82-02 F-Body’s 25
-NIB SLP air temp module 25
-Thunder Racing tensioner anodized red slightly deformed where you insert a ratchet to loosen not really noticeable 150 new my price 100
-Black Chrome ZR1’s with tires 17x9.5 fronts 17x11 rears have chrome center caps with red bowtie that can be removed if needed with some rubbing. Also have a NIB set of 4 SS chrome center caps I can include for additional cash. The tires on the wheels are Yokohamas 275’s front 315’s rear. Passenger rear has minor curb rash that I had quoted to be fixed for 150 just haven’t had the cash to do it. Driver front seems to be slightly struck by a rock or something has a scratch. Looking for 1,000 OBO TRADES ARE WELCOME
Aftermarket Suspension Parts Less than 5,000 miles:
All are in red
UMI Driveshaft Loop with slight rubbing where I broke my driveshaft 70 new my price 50
UMI Chromoly Torque Arm (never seen a track) 390 new my price 300
UMI M6 Torque Arm Relocation Kit (moves torque arm to body instead of transmission) 260 new my price 200
Stock Parts:
-Amber corner lenses 30
-Passenger side t-top (ebony interior) 150
-Bellow 5
-AC Delco amp 30
-MAF 50
-(2) Thermostats
-Oil pump 40
-Timing chain with gears
-Tensioner
-(2) Tensioner pulleys
-Fuel pump setup replaced with high flow pump
-Fuel rails 40
-Crank pulley 40
-Connecting rod bolts
-AIR system
-Front springs recently repainted black just because 25
-Shocks-Decarbons (4) 60
-Motor mounts
-Trans crossmember
-LCA’s 30
-Panhard 20
-Torque arm 20
-Cam 40
-Pushrods 20
-Valvesprings, retainers, locks etc.
-Exhaust manifolds 50
-Front and rear sway bars 60
-4 oem rotors need turning
-Set of used brake pads all have good life left
-ABS block
-10 bolt 3.42 gear 3 channel rear end refreshed about 2,000 miles ago wont include caliper brackets or backing plates reused them with 9” setup 300
*Clutch Items have less than 10,000 miles
-GM Master Cylinder
-GM Slave
-Flywheel
-Clutch
All are in red
Stock Parts:
-Bellow 5
-AC Delco amp 30
-MAF 50
-(2) Thermostats
-Oil pump 40
-Tensioner
-Fuel rails 40
-Crank pulley 40
-AIR system
-Motor mounts
-Trans crossmember
-LCA’s 30
-Panhard 20
-Torque arm 20
-Cam 40
-Pushrods 20
-ABS block
-GM Master Cylinder
-GM Slave
-Flywheel
-Clutch
