Blue71Z
10-14-2009, 11:48 PM
Well here's the problem,
I decided to replace all my front control arm bushings on my 2001 SS Camaro. Since then My ABS INOP and ASR OFF lights have been on. When I was putting the drivers side front back together I accidently dropped the assembly and it cracked the wheel speed sensor. All the internals still looked fine and it plugged back together, but there was no protective plastic anymore. So I replaced it with a used hub from a 99 SS camaro. Install went smoothly and it seemed to match the original hub. I also undid the battery and let it sit the whole time I was doing the install. When I went to test drive it the lights were still on. I once again cleared the codes, reset the battery, and checked the fuses. nothing seems wrong. I am completely stumped and would appreciate any help I can get. I know this could be hard to help without seeing it in person.
Thanks
Thanks
