RocketSSled
10-15-2009, 10:53 PM
I've had this issue before and it has come back.
With the sunroof control switch in the fully closed position, the sunroof mechanism will activate on it's own and make minor open/close movements. It goes away once I rotate the switch from the fully closed to open position and return to the fully closed position.
It seems that there is some dirt / dust contamination in the actual switch. I've read in a thread a while back that the fix was to disassemble the panel to get to the switch and hit is with some electronic contact cleaner. I'm wondering if this is the proper fix and what is the best method in getting to the switch while avoiding any damage to the tabs that hold up the panel in the headliner.
Thanks.
Thanks.
