Drag Racing Results - No 12s for me this year.....
View Full Version : No 12s for me this year.....
qwk93ta
10-17-2009, 05:52 PM
I ran a best of 13.03 @ 107.77 with a 2.029 60' time. Mods are in my sig.
My times ranged from 13.03 to 13.18 all day.....I need more mods to get into the 12s.
Ls1Rook
10-17-2009, 05:54 PM
Damn so close, any weight reduction done
00Silv4.8
10-17-2009, 05:55 PM
not bad for a relatively stock car... tell me, without cam or heads can you really tell me you expected 12s out of the car?
edit: looking at your 60, if you can cut it a little shorter you can probly grab a high 12
qwk93ta
10-17-2009, 05:57 PM
I took the pass. and rear seats out.
AChotrod
10-17-2009, 06:01 PM
Huh???? Why not????
ndfrsd6
10-17-2009, 09:06 PM
do you have drag radials yet ? there is your 12 sec time slip ......
qwk93ta
10-17-2009, 09:25 PM
I have 7 year old Hoosier QTPs and I don't think they hook like they use to.....
custm2500
10-17-2009, 09:37 PM
edit: looking at your 60, if you can cut it a little shorter you can probably grab a high 12
This is a very stupid comment. He was .03 from the 12s. This means in less time than it took you to type one letter of this post, he could have been in the 12s. A bit cooler, a bit less humidity. A bit faster 60ft. like you said and he was there. So why would you make the comment you did? Just looks like time to insert foot in mouth.
Ls1Rook
10-18-2009, 02:51 AM
what psi you running them? sway bar still on?
qwk93ta
10-18-2009, 08:44 AM
I'm running them at 18 PSI and I do have my front sway bar on.
custm2500
10-18-2009, 09:21 AM
I know stank owners who run them as low as 8 psi. I would drop them down to atleast 15. You just gotta make sure you don't loose top end and negate anything that you might gain off the line.
Ls1Rook
10-18-2009, 01:10 PM
you dont need to have them that low on stock stall.. try 25- 30 ... but do a good burnout and theres your 1.9s
removing sway bar will also give your a better 60
just saying these things helped me lower my 60
custm2500
10-18-2009, 03:02 PM
Wow seems like a fairly high pressure. I don't know what the setup was with the 8 psi, but 25 seems high event for a stock stall? You guys know these cars in and out so I gotta assume you know what you are talking about.
qwk93ta
10-18-2009, 03:26 PM
If I go above 20 PSI I can't hook.
TA1364
10-18-2009, 03:37 PM
Come up to kilkare to try and get a 12 before winter.
custm2500
10-18-2009, 03:44 PM
To the op do you run a norwalk? Stinks they close so early! Don't know where you live but if you want to give it one more shot look at Milan, MI they have two more weds they run! i am going the 21st.
qwk93ta
10-18-2009, 04:01 PM
I live a little north of Cincinnati, Ohio....I usually race at Tri-State or Edgewater.
custm2500
10-18-2009, 04:17 PM
Fairly long drive at 3ish hours to Milan..... Or you can wait all winter! Just messing with you. Good luck next time out.
TheBlueKnight
10-18-2009, 04:38 PM
How much do you weigh? If you weigh like 220lbs and your gf weighs 120lb then thats your 12.9 right there if you have her drive. :)
86 IROC
10-18-2009, 10:24 PM
lol Lightweight driver mod. My ex was about 90 lbs lighter than me, the plan was to slowly teach her to drive the car if I got close to 10's... I ended up not needing her though.
To the OP, damn shame your local track closed for the year. I would ditch the front sway bar and make another run at it.
